help replacing the rear wiper motor 2k Blazer
dss56
10-06-2006, 08:22 PM
I'm going to replace the rear wiper motor and need some pointers on removing the rear tailgate moulding. are there any hidden screws or clips? How do i remove this from a 2000 Chevy Blazer?
thanks for the help!!!
alblogg
10-07-2006, 11:21 AM
The rear panel is not that hard to remove. Open rear then open tailgate gate, you can sort of sit on gate to see what you are doing. There is one screw or it my be a rivet it just depends if someone has been in there before or what GM was using that day but start with the panel with a wide flat blade putty knife or your fingers and carefully pull the panel off or find the clips and pry as close to them as possible trying not to break them or your panel. Work your way around the top and bottom until they are loose and then loosen the screw or drill out rivet under handle.
