Cutting out really bad.. 86' grand am
Taek
09-30-2006, 08:51 PM
Heya, I have an 86 Pontiac Grand Am.. I've been trying to figure it out, But I'm having no luck.. Usually going down the high way.. I'll hit about 50mph, and I'll start to lose power, If I continue accelerating to 60mph, The car will actually start cutting out really bad, As if it wasn't getting enough gas or something.. I'll end up losing speed till i'm back down to 40ish ( or lower ) , then accelerate and the car will be fine for a little bit ( not always ) .. Also, The other day I was going up a semi steep hill, I hit it in 4th gear, Ended up having to down shift clear to 1st gear and was moving at about 10mph up the hill, As I got to the top, I stopped giving it gas and it actually died on me..
If anyone has any idea on what could be causing this, I'd really appreciate any feedback!
Thanks in advance =)
skibum1111
09-30-2006, 09:12 PM
It sounds like either the fuel filter is clogged or the fuel pressure regulator has some crud in it. It definately sounds like a fuel related issue. Good luck.
Taek
09-30-2006, 09:17 PM
Yeah, I definately feel its fuel related also, I have changed the fuel filter.. which seemed to help at first.. but now its back to acting like it was..
I'm not familier with the fuel pressure regulator though
