Painting Calipers
Black99GST
09-28-2006, 04:24 PM
anyone know what type of paint looks the best? i cant afford powdercoat, otherwise i would, but i'm getting some 2 piston calipers, and want to paint them red... anyone have any inside on what paint looks the best, and lasts long?
xavier3jr
09-28-2006, 06:28 PM
you can buy caliper paint at advanced for like 25 bucks
eclipsekid
09-28-2006, 07:42 PM
Yeah, what he said. I think Duplicolor makes it. I painted my calipers with that stuff and it looks great and has lasted without chipping or anything like that (6 months so far). Just make sure you clean up the calipers pretty well before you apply. You could either take the calipers off, or just do what I did, and leave them on and carefully apply the paint with the brush provided.
FYI, you only need to buy one kit, since the amount of paint they give you is probably enough to do like 20 cars.
Check this stuff out. You'll be Brembo-like stylin' in no time!:smokin:
david-b
09-28-2006, 10:56 PM
Umm... I paid $6 for my can. Don't know what it's called but Get In the Zone, AutoZone had it.
xavier3jr
09-28-2006, 11:33 PM
and we all know how pickey david is... lol i would trust his judgement
Black99GST
10-02-2006, 02:31 PM
lol yeah i found the one at advanced for like $16 just wanted to make sure it was actually worth $20... lol thanks!
david-b
10-02-2006, 02:51 PM
Watch it Travis... I am picky, but paint is paint... and it was caliper paint.
Black99GST
10-03-2006, 05:55 PM
ok, does anyone know whats the best way to clean them?i was originally going to sand blast them, but i cant figure out how the get the pistons out of the caliper. they are pretty dirty, with a lot of build up on them. they also have a little rust. any suggestions?
xavier3jr
10-03-2006, 08:46 PM
get a can of carborator cleaner and a brush and some soap and that should do the job
Black99GST
10-03-2006, 08:54 PM
is there anyway to pull the pistons out of the caliper, so i COULD sand blast it?:uhoh: or i was also thinking some sand paper... also, would brake cleaner work as well as carb cleaner (worried about the rubber seals reacting w/ the carb cleaner)
david-b
10-03-2006, 09:37 PM
I used brake cleaner and a brush. Worked fine.
Black99GST
10-03-2006, 09:38 PM
alright thanks!
nova1313
10-04-2006, 09:24 AM
I agree carb/brake cleaner. I used the 5 dollar can from Auto zone. Mine went gold.
Black99GST
10-05-2006, 11:53 AM
ok, will i cleaned them with brake cleaner, and they are still rusty, anyone know a way to get the pistons out of the calipers (w/o access to the car?) because i think i'm going to just sand blast it. but i wanna take it apart because i'm worried about the rubber seals. thanks.
corning_d3
10-05-2006, 01:22 PM
Just give it a good spraying with brake parts cleaner, and remove the rest with a brush, soap, and water. I used VHT red from autozone in a rattlecan. I put it on 3 months ago, and it's still there...even after gravel roads and a brake job..
Black99GST
10-05-2006, 02:45 PM
like a wire brush? because i tried with a tooth brush, and used almost a whole can of brake cleaner on one caliper, and its still dirty as hell!!!
corning_d3
10-06-2006, 12:04 AM
That would probably work, I used a stiff bristled BBQ grill brush, then a scrub brush 'n' Dawn dish soap.
Black99GST
10-06-2006, 12:47 PM
:thumbsup: thanks for the tip!!!
