Clarion Stereo Pinout Needed...HELP!
ronbinnixamo
09-01-2002, 10:16 PM
I need the pinout as the plug on the back of this Clarion PN-9945M from a 95 Altima is gone. I've searched and searched...don't wanna spend the money to buy it (I know, cheapskate!), can anyone help? PLEASE? Thanks!
Ron
Ron
elcuete
05-24-2003, 02:25 PM
hi, did you ever get the pin out of the clarion? I am in the same situation. my stereo has the plugs with the wires cut about 2-3 inches out. the wires as you look at the back starting with the small plug are :
bottom row skip the first pin next pin is black/white the the third from
the left is orange, fourt on the bottom row is grey/red and above the
4th pin is a grey wire. on the big plug the top row has 4 pins and the bottom row has 6 pins. the wires are as follows
top row: purple on pin 1, brown on pin 2, red/grey pin 3, blue/pink pin 4
bottom row:
green/grey pin1,brown/white pin 2, pin 3 empty, pink grey pin 4, red/white pin 5, and pin6 of the bottom row is empty.
i believe that the orange and black on the small plug and the two greys on the small plug are speaker wires as are the green and purple and the two browns. the red and pink and blue i'm not sure of but the claruon web site says red is positive and blue is power antenna the rest is a mystery. I copy and pasted the clarion wiring list i got from them.
if you can make sense of this please elmail me at
[email protected]
White=left front +
White/Black=left front –
Gray=right front +
Gray/Black=right front –
Green=left rear +
Green/Black=left rear-
Violet=right rear +
Violet/Black=right rear –
POWER/ACCESSORY
Yellow 14ga=battery main/memory
Yellow 18ga=battery CeNet power/memory
Red=accessory (ignition on)
Black=ground
Blue=antenna turn on +
Blue/White=remote turn on (amps) +
Orange/White=dimmer
Brown=phone mute
Orange=parking brake video lockout
White/Red=CCD (camera) input instant on +
bottom row:
[email protected]
White=left front +
Gray=right front +
Green=left rear +
Violet=right rear +
POWER/ACCESSORY
Black=ground
Orange/White=dimmer
Brown=phone mute
Aprendiz
06-24-2006, 10:09 PM
hi there
please tell me what is the function for each cable in each pin.
Thanks:crying:
Thanks:crying:
sparkeykev
07-03-2006, 11:56 PM
White=left front + left front speaker pos
White/Black=left front – left front spkr negative
Gray=right front + right front spkr posative
Gray/Black=right front – right front speaker negative
Green=left rear + left rear speaker posative
Green/Black=left rear- left rear speaker negative
Violet=right rear + right rear speaker posative
Violet/Black=right rear – right rear speaker negative
POWER/ACCESSORY
Yellow 14ga=battery main/memory constant battery power not off with key out
Yellow 18ga=battery CeNet power/memory same as above
Red=accessory (ignition on) batery power with key on or acc only
Black=ground batery negative or car body
Blue=antenna turn on + electric aerial output posative
Blue/White=remote turn on (amps) + accesory amplifier output posative
Orange/White=dimmer Park light feed to dim radio display when night time
Brown=phone mute if cell phone fitted phone ring mutes radio
Orange=parking brake video lockout if video display fitted handbrake feed activates display if handbrake on no display whilst driving (safty device)
White/Red=CCD (camera) input instant on + power feed for camera
hope this is of some help
POWER/ACCESSORY
alejandromp
07-21-2007, 01:04 AM
I have CLARION PN-9945M
its diferent pinout
left to right up
Violet Brown none Red Blue
left to rigth down
Green White/Brown Pink Orange none
Help me
:banghead:
[email protected] thanks
its diferent pinout
left to right up
left to rigth down
Help me
:banghead:
Rob Jackson
04-07-2009, 11:51 AM
There are two types of clarion pinouts. A 16 pin and a 14 pin. I was able to figure out most of the 14 pinout for my 2003 Hyundai Accent.
Isn't it strange that neither Hyundai or Clarion will admit to making this radio?
Looking at the back of the radio, the top row is numbered 1 to 7, left to right and the bottom from 8 to 14.
Pin 1 (orange) left with no connection, I couldn't figure out what it did.
Pin 2 (Blue/Wht) see pin 1
Pin 3 Red. SWitched 12 volt from ignition.
Pin 4 Green/Blk spkr 1
Pin 5 Green spkr 1
Pin 6 Wht/blk spkr 2
Pin 7 Wht spkr 2
Pin 8 Yellow 12 volt (constant hot)
Pin 9 no connection
Pin 10 Blk ground
pin 11 vio/blu Spkr 3
pin 12 vio spkr 3
pin 13 gry/blk spkr 4
pin 14 gry spkr 4
The colours are for the wires coming from the plug I bought for the back of my radio. They may not be the same for all other plugs.
I took the second colour on the spker wires to be the negative side. In my car, I can't tell the difference when I tried to reverse one pair, but I wired them all the same to provide an equal impedance for the output drivers in the radio.
The hot wire (pin 8) is fused near the battery so if you can't find it check the fuse. The same fuse on my car also works the clock so if the clock resets everytime you turn on the ignition check that fuse.
To set the time on the radio: first turn off the radio, then push and hold the display button until the display flashes. The up and down buttons set the minutes and hours. You can play with it until you figure it out.
Best of luck
Pin 5 Green spkr 1
Pin 7 Wht spkr 2
Pin 9 no connection
Pin 10 Blk ground
pin 12 vio spkr 3
pin 14 gry spkr 4
Best of luck
