Shifting problem
lkist0133
09-27-2006, 01:37 AM
I have a '93 Ranger with the 2.3 and a 5spd tranny. Every once in a while when I back up and try to shift into first, or any forward gear, I'm not able to. As soon as I shift back into reverse I can then shift into first gear. Sometimes when I have to go back to reverse the gears will grind as it slips into gear. Does anyone have an idea of what might be going on?
jinraiden
09-27-2006, 02:27 AM
What kind of tranmission fluid do you use? I'd replace whatever you're using with MT-90 or GM Synchromesh. The latter works wonders, you'd be surprised how much more crisp your shifts are... unless your tranmission is too far gone.
lkist013
09-27-2006, 08:04 PM
I'm not sure what was in there before, but I drained about half to see what it looked like and filled it up with automatic tranny fluid which is what a teacher reccomended.
