fuel cut question
LouieAWDTSi
09-27-2006, 12:20 AM
Ok.. so my boost went up the past week for some reason and I hit fuel cut. I'm pretty sure I did. Car slammed pretty good like if I took my foot off the gas and then slammed the gas again( like a huge sputter). Is it true to take the negative wire on the battery off for a few seconds to the let the ecu retsart so it doesn't remember fuel cut? Thats what I read before but I didn't know if it was true.
And will my saf-c1 lose its settings if I do take it off?
david-b
09-27-2006, 12:36 AM
SAFC will not lose settings. It's al saved internally. IDK if resetting the ECU will make it forget fuel cut. Fuel cut is always there. I see you rewired the FP. Did you reset it then when you did that? I would imagine you did. I mean, you can give it a try, but it may be something else.
4g63gst20
09-27-2006, 02:16 AM
Now that we are in the topic, i just installed a 14b in my gst and i after i installed it, it was boosting 18 psi at full boost. i never boosted 18 psi for more than 3 secs. and one day i decided to step on the gas on 3rd gear and i loved it at 18 psi, but then i hit fuel cut. so i rewired my fuel pump, and i still cant boost 18psi without fuel cut. i just read here that i was suppossed to reset the ecu which i didnt know. then 2 nights ago i got a cell and was gone 1 day later and came back tonight. does fuel cut give a cell?
Eclipse4ever
09-27-2006, 03:34 AM
Does the car make a loud "bang" noise when it hits fuel cut? Does it make any noise at all? Any smoke ? Apperantly when my car hits fuel cut, white smoke comes out of exhaust. Those were the words of Mitsu Mechanic at the dealership.
LouieAWDTSi
09-27-2006, 04:12 PM
It makes a loud bang. Yea I dont think I ever took the wires off the negative terminal since I did the rewire last winter. I went by plymouthlaser.com's directions and I didn't remember seeing that. If this works it be amazing. Let ya know.
Black99GST
09-27-2006, 05:17 PM
you shouldnt have any problems with fuel cut on a rewired FP... reset your ECU... *you rewired your fuel pump with out disconnecting the battery, yu got balls... like HUGE ONES!!!* :2cents:
LouieAWDTSi
09-27-2006, 05:59 PM
lol it was about a year ago so i can't remember if I touched the negative side or not. I did like 10 mods in two days that week. I reset the ecu and tried lowering my boost and I think my mbc is on its last life because it's not really adjusting the boost as I adjust the lock nut. Maybe I'll keep my eyes out for a new boost controller. Either way when I made two hard pulls, it didn't hit fuel cut but I dont plan to floor it really until I get the boost lower.
steviek
09-27-2006, 07:14 PM
What about the injectors, they may not be supplying enough fuel.
LouieAWDTSi
09-27-2006, 08:28 PM
Well i hit 23 psi today when I floored it after resetting the ecu and I didn't hit fuel cut. I'm worried about my mbc right now. I basically closed it to the point where I should be barely hitting boost and it's still hitting 23ish. I want it back down to 16ish. Everything looks fine too.
scottsee
09-27-2006, 09:15 PM
Fuel cut is when your airflow hits 2.55g/rev. Boost & fuel have nothing to do with it. Things like that are easy to find with the help of the elusive search button...
david-b
09-27-2006, 09:53 PM
But doesn't boost affect airflow?
scottsee
09-27-2006, 10:21 PM
It's dependent, but not the cause.
LouieAWDTSi
09-28-2006, 03:00 PM
Ok well today, I adjusted my mbc and couldn't get it to settle under 20psi. My vacumme seems fime according to the gauge and I even tried my friends mbc and it still didn't lower more then 20psi.
Any suggestions on what is going on here?
