D16 bore question.
ZDuRose
09-26-2006, 11:40 AM
If I bore my D16a6 and bore it to 1.7 with the pistons from the D17a1 work for me? or are they the wrong shape for the valves. I've been looking and can't find pictures of the pistons and i don't want to order any if they are wrong.
TheSilentChamber
09-26-2006, 12:57 PM
d16 and d17 have the same bore.
Hybrid1990crx
09-26-2006, 05:28 PM
i wouldnt really trust that since the d17's seem to vary from other D's, valve clearance might be the different, only way to really know is to clay the pistons.
you can get overbore pistons for your stock block.
TheSilentChamber
09-26-2006, 05:36 PM
I have a set of d17 pistons right here, they're dished, no valve recesses- well the intake side has two, but they maby 1mm wide by 4mm long and maby 1mm deep.
Hybrid1990crx
09-26-2006, 05:48 PM
ok and whats the lift and duration on the d17 cam compared to the d16?
and what about the a6 being non vtec?
TheSilentChamber
09-26-2006, 05:53 PM
I wasnt saying they would work, I was just saying what they looked like. I believe they also have a shorter compression height, but I'm not possative on that.
ZDuRose
09-26-2006, 09:46 PM
well the D17a1 is also Non-Vtec, what happened is my timing belt slipped and my block was saved thankfully, it was just lightly scored and so it needs to be bored out, but it would be cheaper for me to bore it and get all new pistons then bore it resleeve it and get a new piston and connecting rod. So i haven't found bigger pistons for the a6 so i like i said, i was wondering since the D17 is the 1.7 liter, if the piston would work.
maxassassin
09-26-2006, 09:49 PM
the d17 is a 1.7 due to stroke. nto the pisto nsize. theres many variables you need ot consider on this. but as far as the a6 well you could by high compression piston from the dohc zc or low ocmrpession pistons made for our civics for boost or im sure there other manufacturers out there.
TheSilentChamber
09-27-2006, 07:20 AM
There are handfulls of companies that make oversized pistons, honda probably even offers them.
Hybrid1990crx
09-27-2006, 10:12 PM
ah that is true, i dunno what i was thinking.
i really don't see a need in using d17 pistons, im sure honda sells a 20 overbore piston for rebuilds, like TSC said.
