Tuning...
Mikelb
09-25-2006, 10:17 AM
Hey, I need some help making sure my tuning is ok...
I haven't had any problems out of the car (that I know of), but wanna be safe and efficient...
Ok, I live in NC (125 ft above sea level)
I run 93 Octane fuel
Boost set at 16.5 (spikes 17)
hacked MAF
K&N filter
SAFC II (stock settings)
2.5" exhaust
stock turbo and motor
I haven't set any correction on the SAFC, and it doesn't show any knock... I didn't know if I'd need a DSMLink or anything like that to tune it initially, I do have plans to pick one up, but money is tight right now...
My A/F gauge shows the car rich when I get on it, and it sweeps when I cruise, so I'm guessing everything is ok, but I know that the O2 sensor is too slow to use it to tune... so any suggestions? tips?
clipsekid99
09-25-2006, 11:26 AM
hacked MAF
K&N filter
2.5" exhaust
First, I'm pretty sure, well atleast for 2g's, but the knock signal on the safc doesn't work for our cars. Second, don't trust the blinky light-show on that Autometer A/F gauge UNLESS you are running a wideband o2 sensor. Other than that, there isn't much else to tune, since you haven't really messed around with the fuel. You should get a datalogger, or like you said, DSMLink soon to see what kind of things are going on inside your ecu to help you tune it.
Mikelb
09-25-2006, 12:07 PM
oh yeah, I'm sry... I have added a Walbro 255lph fuel pump, and a FMIC...
I forgot a/b those...
and don't have a wideband... and I don't recall hooking up a knock sensor wire, but under sensor check there's voltage (when car is running, but not when it's off)... so I didn't know for sure...
Black99GST
09-25-2006, 12:58 PM
link.
david-b
09-25-2006, 02:16 PM
Yeah, you shouldn't have any knock reading on the SAFC on 2G. The only way to trust the F/F guage without a WBO2 is at WOT and if you know what the readings on the gauges are set to. I have a datalogger and I know when the second to top red bar is fully lit and the one above it just starting to light up, the A/F is almost perfect. I believe it's about .94 or so. That will change with all gauges though. And you don't want to always trust that. If I make a change on the fly without a logger hooked up, I always test it out with the logger right when I get a chance. Don't start tuning on that without a logger or DSMLink.
Mikelb
09-25-2006, 02:42 PM
sry, mine is a 91(1st gen)...
david-b
09-25-2006, 09:52 PM
Ahh. Totally missed that. Still, tuning is still the same.
Mikelb
09-26-2006, 07:33 AM
alright, I'll start saving the money to get the DSMLink
kjewer1
09-28-2006, 08:04 AM
I just want to bring attention to this page (www.posracing.net/afr.html) again, the pic at the bottom that illustrates how the front O2 sensor can read .98 while the wideband reads 13.5:1 as 3 of my 4 pistons make thier way out my exhaust. ;) Be VERY careful when looking at front o2 voltage.
Mikelb
09-29-2006, 12:57 PM
is this a good deal for a datalogger?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=220031586443&ih=012&sspagename=STRK%3AMEWA%3AIT
xavier3jr
09-29-2006, 11:20 PM
thats the same one i have kinda tricky lol but it works well
