Amp help/Audioband AW1206T Subs
sfknls
09-24-2006, 08:41 PM
BRAND NEW PAIR OF AW1206T SUBS!
12" Dual Voice Coil Subwoofer
1100W RMS / 2200W Peak Power Per Sub
Dual 4Ω Voice Coils
Protective Chrome Finish
2.5" 4-layer Voice Coil
Vented Back Plate For Cooler Operation
Stamped & Balanced Aluminum Cone
Flame Q Design in Basket, Magnet and Cone
Double Stacked 120 oz. Strontium Magnets
2" Foam Surround For Linear Cone Travel
20-500Hz Frequency Response
96.4dB Sensitivity
Multi-Connect Lug Lock Terminals
Audiobahn Window Sticker
Allen Wrench For Speaker Terminals
Wooden Gift CaseWhat would be a good amp for there speakers? I already have two 800w American pro Amplifiers?
400 watts x 2
Bridgeable to 800 watts x 1
24db / Oct Built-In Crossover Slope
Remote Bass with 20 foot wire
Variable Subsonic Filter (10Hz - 100Hz)
Variable Low pass filter
Variable High Pass Filter
Variable Bass Boost
Mosfet DC-DC Converter
Top Function Control
2 ohm stable
tri-speaker hookup
Remote on/off by 12V
Power and Diagnostic LED Indicator
Gold Plated RCA & Terminal Connectors
Delay Turn On Option
NOTORIOUS170
09-25-2006, 02:18 PM
what to look for:
your sub will run in 2 ohm or 8 ohm operations. 1000 watts per sub would be perfect. for that find an amp that is 2x250 RMS at 4 ohm per each sub. when bridged, the amp will run at 2 ohms and should max out at 1000 watts.
pimprolla112
09-25-2006, 08:30 PM
I wouldnt push 500w to an audiobomb, let alone 1100. Look into either a 1ohm stable amp from PPI, hifonics. Or 2 seperate amps from profile at about 500rms each.
Those amps you have are about 150 rms believe me legacy amps are over rated to the point of retaradation, there like 4 times over rated for power. 300-500 should be enough power for those subs,audiobahn over rates power alot to.
NOTORIOUS170
09-26-2006, 05:59 PM
im pushing at least 1500 to my sub and its running fine.
balls_to_the_wall
09-26-2006, 07:09 PM
I'm doubting your pushing 1500 actual watts.
pimprolla112
09-26-2006, 08:24 PM
LOL,i was trying to find the rms specs all i could find was 500x1 @ 4ohm, and 1000X1 @4ohm bridged, how do you bridge a damn mono amp i dont know.
Not to be a dick but a majority of audiobahn is over priced junk.
NOTORIOUS170
09-26-2006, 10:03 PM
1x500@4ohm
1x1000@2ohm
1x2000@1ohm
2ohm dvc run in parallel/parallel give a 1ohm load.
am i getting 2000 watts? doubt it. 1500? probably. the sub in a 2.5cuft box tuned to 35 hz puts out 139.5db. did i mention it was 1 sub?
anyway, i didnt ask you to believe me. i was just lettin the man know what i was puttin to my sub.
if there are any ?, my sub is the audiobahn awt12x and the amp is the
a4125hct.
if you have 1 sub and are putting out more that 139.5, congratulations. otherwise, shut the f**k up because i know what the hell im talkin bout.
coop
pimprolla112
09-26-2006, 10:23 PM
Hey coop guess i can call you that. Try 2 subs made in 96 with 150watts rms. Yeah 138 on the new TL mic, and 139 on my uncles old TL mic. Thats 75 watts RMS to each sub. 2-polk EX-II's 12's. Theres more to car audio then throwing a sub in an enclosure and pumping power to it, enclosure design, and vehicle have a huge impact.
ANd by the way ngsm is hitting 150+ with 1 sub.
NOTORIOUS170
09-26-2006, 10:30 PM
thats a damn good setup. good numbers for 150 watts.
what kind of sub is ngsm running?
pimprolla112
09-26-2006, 10:43 PM
i believe when he did that he was running a RE-MT 15" not sure on amp(s).
Heres a thread he posted about a month ago.
http://www.automotiveforums.com/vbulletin/showthread.php?t=613464
as you can see he doesnt play around.
Your from VA you go to any shows in MD.
NOTORIOUS170
09-27-2006, 05:59 PM
only the ones i know about that are within 3 hours of me. i know of 2 in october. 1 in nova, and the other by the va/nc border at virginia international raceway (see sig). the on in nova is at marine base quantico and its on the 15th. http://www.notoriousnissans.com/images/WTBSHOW.doc
pimprolla112
09-27-2006, 07:32 PM
I was talking more like so. md like MIR.
I havent been to a show in VA in like 2 years. Last one was HIN, it was awsome but i like racing more than i like show. But my truck will be in some comps soon, waiting on my hood, roll pan, front bumper, 18" wheels. Im not going for full show, i want some speed.
balls_to_the_wall
09-28-2006, 12:15 AM
I'm curious as to what mic/sensor that 139.x was on? :)
NOTORIOUS170
09-28-2006, 10:08 AM
well i try to stay up on the shows in the local area, so if you ever wanna see if i know about one thats coming up, hit me up or stop by my site. Upcoming Events (http://www.notoriousnissans.com/upcomingevents.htm). the one at VIR is like 300 miles for me so thats gonna be a journey but its gonna be a bomb a** show. theres so much goin on there. cant wait until next weekend.
pimprolla112
09-28-2006, 10:40 PM
Let me call him tomorrow to find out. It was close to about a year ago when we did it with his mic, then the competition was about 2 months after that, i wasnt entered i just wanted to see what i would hit.
