can it handle 400hp?
drag1286
09-15-2006, 08:38 PM
I have found a way to achieve 400hp from an `87-`93 302ci while using a stock cam and maintaining natural aspiration with a $3000 budget including the stock engine. The problem is that I have no idea if the corresponding stock 5-speed transmission will withstand that kind of thrashing "more than twice." If not, what is the better alternative? :screwy:
Thanks for any and all usefull info!!!
neatofrito1618
09-15-2006, 11:23 PM
A T-5 is a wild card, some people have been running that long term without any problems and some people have blown it running much less. Obvously power/speed shifting is a no no, if you want to strengthen it you can G-Force it, but those kits are very expencive.
SkylineUSA
09-16-2006, 12:03 AM
How are you going to acheive those numbers? N2O or Boost? Its N2O, that a big shock to the drive train, boost is a little softer.
My T5 WC had 30,000 miles on it, til I sold the car. It was still as strong, and shifted without any issues, but I had an S-Trim. If it had N2O for the power adder, I think the trans would have bought the farm by then.
neatofrito1618
09-16-2006, 01:13 AM
My T5 WC had 30,000 miles on it, til I sold the car. It was still as strong, and shifted without any issues, but I had an S-Trim. If it had N2O for the power adder, I think the trans would have bought the farm by then. He said he's staying N/A, which I dont see happening if he's trying to reach 400 hp.
SkylineUSA
09-16-2006, 12:50 PM
What do you mean, he will be using a stock cam:screwy:
GTStang
09-17-2006, 08:36 PM
By stock he means it fits in the stock block :evillol:
drag1286
09-18-2006, 07:27 PM
Hey thanks for all of the replies, as far as the horsepower for dollars spent I simply found an inspiring technical article from CarCraft. I think this is the link
http://www.carcraft.com/techarticles/116_0307_ford_302_v8_engine_buildup/
Obviously I'm unfamiliar with the hardware so here are my questions...
1- Is the "T-5" the stock tranny? and where can I find details on a "G-Force kit?"
2- Are there any aftermarket companies that produce complete trannys at that hp rating? :screwy:
Thanks everybody!!!
Thanks everybody!!!
AltecZX2
09-19-2006, 09:59 AM
interesting article
TheStang00
09-19-2006, 10:33 AM
very interesting article. thats why ford needs to go back to making engines with a larger bore like they used to. the mod motors are more square in design for emissions.
AltecZX2
09-19-2006, 04:38 PM
Would this also apply to the 94-95 GT's?
TheStang00
09-19-2006, 04:46 PM
i dont see why not, its the same engine. they actually show the increase on a 95 gt with the 165cc heads on the airflow research website. just the heads alone on their website give a 41hp increase.
neatofrito1618
09-23-2006, 08:21 PM
Thanks everybody!!! Yes it's a T-5, http://www.gforcetransmissions.com/tran_gt-5.asp
SkylineUSA
09-24-2006, 01:53 PM
Wow, if its true.
Dyno numbers really do not mean much.
AltecZX2
09-24-2006, 02:53 PM
Wow, if its true.
true have to factor in weight, track, rim/tire rotation/size and gearing
fivepointohhhh
09-29-2006, 07:58 PM
imo the stock tranny starts to shit out at anything above 350 horse, id say get a tremec.
rob10s2
10-02-2006, 11:17 PM
i read that article when it came out years ago, im building it when i have the coin
tturnpaw
10-04-2006, 11:37 PM
well the regular T5 i had in my 82 lasted about 4 months of strong shifting at about 330 crank horsepower. when i got a rebuilt wc it lasted about 2 years and now its finally going out, so its all up to you. rebuild wc or upgrade.
fmfgnarly
10-14-2006, 07:20 PM
^^^I remember that stuff. Those were some good times!^^^ LoL
