getting no fuel
cbmusic66
09-11-2006, 03:02 PM
I have a 1995 Ford Ranger 3.6 6cyl. and we are not getting any fuel through.
I have replaced the fuel pump, fuel filter and relay switch. Removed the fuel filter and there is no gas getting through at all. Someone recommends the ignition coil or module? any recommendations?
Thanks in advance!
Cat Fuzz
09-11-2006, 07:33 PM
If I remember right, there is an enertia switch on those things that can be tripped accidentally or for some other reason. I don't know where it is but I remember a friend having this problem. They are designed to cut power to the fuel pump in case of a wreck.
KimMG
09-12-2006, 04:25 AM
Have you checked the power supply to the fuel pump? Have you made sure that there is enough fuel in the tank for the pick-up tube to reach?
n1dhead
01-11-2007, 02:32 PM
Thanks in advance!
look on the passenger side where you left foot would be there is a fuel pump reset switch you might have to pull the carpet down a bit to get to it push the red button see what happens!holla
e_powers
01-11-2007, 11:44 PM
yeah another forum i hang out at has someone jokinly stating how their drunk friend kicked his dash board and tripped the switch.
