ls1 - ls7 whats the difference?
gman_128
09-04-2006, 08:23 PM
hey im looking at trans am's and i was wondering what is the difference between an Ls1 - ls7, lke what is eunique to each model?
thanks
Mr. Luos
09-04-2006, 09:24 PM
LS1 = 346
LS7 = 427
Blocks are the same size, but that is about it. The overall design is the same, but the heads, cam, rods, etc. are all different.
If you were to look at the motors assembled and next to each other, you would see very similiar motors.
doodad
09-04-2006, 09:54 PM
also Curtis, was there any LS1 f-body built with LS6 block?? there is a dude who owns 200 LS1 camaro and he said that some of them came with LS6 block and l said no 01-02 came with LS6 intake but this dude PMed me and said there were some with LS6 block.. is this correct??
(sorry kinda off topic)
Mr. Luos
09-04-2006, 10:19 PM
Some 2002's did get the LS6 block.
Not the LS6 internals though.
poormillionaire2
09-04-2006, 11:09 PM
I got the impression from the way I read the post that Gman thinks that the TA had either the LS1 or LS7.
Just to clarify, the 98-02 v8 f-bodies only had the LS1. The newest Gen IV block, the LS7 only comes in the new Z06 Corvette.
blue02ws6
09-09-2006, 06:36 PM
Some 01's came with it also. Very few but they did. The only differences in the ls1 and ls6 are heads and cam anyway.
Mr. Luos
09-09-2006, 07:14 PM
The LS6 block is a touch different as well. I can't remember the difference right now.
hotrod_chevyz
09-10-2006, 09:18 PM
The LS7 shares the same basic Gen IV V-8 architecture as the Corvette’s 6.0-liter LS2, but the LS7 uses a different cylinder block casting with pressed-in steel cylinder liners to accommodate the engine’s wide, 104.8-mm-wide cylinder bores; the LS2 has 101.6-mm bores. And when compared to the LS2, the LS7 also has a different front cover, oil pan, exhaust manifolds and cylinder heads.
Internally, the LS7’s reciprocating components make use of racing-derived lightweight technology, including titanium connecting rods and intake valves, to help boost horsepower and rpm capability. The rpm fuel shut-off limit is 7000 rpm.
The LS7’s specifications include:
Unique cylinder block casting with large, 104.8-mm bores and pressed-in cylinder liners
Forged steel main bearing caps
Forged steel crankshaft
Titanium connecting rods with 101.6-mm stroke
Cast aluminum flat-top pistons
11.0:1 compression
Dry-sump oiling system
Camshaft with .591-inch lift
Racing-derived CNC-ported aluminum cylinder heads with titanium intake valves and sodium-filled exhaust valves
Titanium pushrods and valve springs
Low-restriction air intake system
Hydroformed exhaust headers with unique “quad flow” collector flanges>i got this info from corvette museum.
