automatic to manual switch
hasvold
09-03-2006, 02:55 AM
my LT1 unfortunately is automatic. I want to switch my tranny to maual. How much am I really looking at, and what are some criterias to keep in mind? I was thinking about B&M short shifter or hurst. Any suggestions?
poormillionaire2
09-03-2006, 07:46 PM
Are you gonna buy a brand new tranny or a used rebuilt one? I think I found in a magazine a company selling new Tremec 6-sp for $1999. Its the same as they put in vipers (if that means anything to you).
Labor charges aren't gonna be cheap, but you'l' have to ask around your area for quotes. I know most places charge $400-$600 just for a header install.
Good Luck.
ZL1power69
09-03-2006, 11:14 PM
realistically, your better off selling your current car and buying a factory 6 speed one as the conversion cost will most likely come close to, if not exceed the value of the car. but you can find a used tranny for a fairly good price (i've seen my local yards sell t56's for between 500 and 1000 bucks). then you have to factor in installation costs, unless you are gonna tackle that on your own.
97cavalier
09-04-2006, 09:36 PM
and just to let you know, a auto is faster than a stick, expecialy with a diffrent stall.
hasvold
09-04-2006, 09:48 PM
how would you figure that an automatic is faster than a stick??
97cavalier
09-04-2006, 09:51 PM
an auto never misses a shift, and always get a perfect shift, and with a high stall torque converter it will take off WAY faster. And in a stick will will not always get a perfect shift and you will miss a shift sometimes.
hasvold
09-05-2006, 09:40 PM
i guess that makes sense, except i always thought that having stick ment quicker start b/c of higher rpm range
97cavalier
09-05-2006, 09:45 PM
that is what a high stall torque converter does. it takes off alot faster. A auto with a shift kit and gear and a high stall will smoke any stick.
poormillionaire2
09-05-2006, 10:05 PM
Agreed, an auto eats stick if set up right, from a dig. From high rolls, like on the street, I would have to tip my hat to the manual (more gears and closer gearing).
But an auto with the proper stall will launch harder than a manual with the same setup.
