04 v6 rear end swap
98w_mc
08-29-2006, 09:50 AM
Can a 04 v6 have a saleen, cobra, or gt rear end swaped, the purpose is for the LSD to give equal traction to rear wheels. The car is a 5-speed also. Thanks.
BlackGT2000
08-29-2006, 02:12 PM
I believe that the Saleen and the GT have the same rear, but yes the GT rear and the Cobra Independant rear will both bolt into the V6's mounts. I don't know if you will need a new drive shaft or not though.
TheStang00
08-29-2006, 03:48 PM
you dont need to swap the rear to get lsd... you can stick that on ur stocker....
98w_mc
08-29-2006, 04:30 PM
How can you got an lsd without replacing the rear end, what do you have to buy.
98w_mc
08-29-2006, 04:47 PM
Hey guys I did some research on the t-lock and found this t-lock for v-6s.
Link:
http://www.speedconcepts.net/product_info.php?products_id=209
Keep the info coming though, thanks.
neatofrito1618
08-29-2006, 06:10 PM
Yep, all you need is a T-loc on your 7.5
mustangman02232
09-23-2006, 02:03 PM
t-loks are garbage and i cannot recomend them, they were built for the 120 HP bronco 2/ranger with a limited slip,
detroit true trac & TA rear girdle FTW!!!!!!
http://www.drivetrainspecialists.com/categories/ford/ford-75/index.html
that setup should be able to handel 400+ HP
