2003 Taurus 24v DOHC Duratec - PCV valve
jpjj
08-26-2006, 06:14 PM
Exactly where is the pcv valve located on the 24V DOHC Duratec engine?
DistanceGuy1
08-27-2006, 03:37 PM
Should be under the manifold
jpjj
08-28-2006, 05:54 PM
I found it but I was unable to remove it. Are there any tricks?
brokenantimatter
08-28-2006, 07:22 PM
I found it but I was unable to remove it. Are there any tricks?Needle nose pliars. Usually they are just gunked in a couple are screwed but the duratec should just be shoved in.
mwt878991
08-29-2006, 06:15 AM
The manual says to turn it 90 degrees.
The concensus is you have to pull the UIM and the fuel rail otherwise you will run the risk of breaking it when you start pulling on it.
I havent ever changed it.
Mike
:smokin:
Mike
:smokin:
brokenantimatter
08-29-2006, 08:00 PM
I typically take pictures of every car job I do:
http://jappleng.com/private/peyton/images/taurus/pcv/0A.jpg
http://jappleng.com/private/peyton/images/taurus/pcv/0B.jpg
http://jappleng.com/private/peyton/images/taurus/pcv/0C.jpg
http://jappleng.com/private/peyton/images/taurus/pcv/0D.jpg
http://jappleng.com/private/peyton/images/taurus/pcv/0E.jpg
mwt878991
08-29-2006, 08:24 PM
Cool!
What year Duratec is that?
Mike
:smokin:
Mike
:smokin:
brokenantimatter
08-29-2006, 09:52 PM
Either my 1996 or 1998.......probably the 1996.
shorod
08-29-2006, 10:54 PM
I would guess the 1996 as well. Didn't the 1998 have electronically controlled intake runners? The one in the photos appears to be vacuum actuated.
-Rod
-Rod
