shift kit
Jcrane88
08-26-2006, 11:32 AM
basically how do i tell if i have one?? me and my dad took my Z28 out for a run yesterday...we suspect that the transmission has a shift kit installed but i dont know how to verify that
FormulaLT1
08-27-2006, 11:25 AM
basically how do i tell if i have one?? me and my dad took my Z28 out for a run yesterday...we suspect that the transmission has a shift kit installed but i dont know how to verify thatOnly way I can think of is to remove the valve body and check for spacers. Besides that its pretty complicated.
silicon212
08-27-2006, 11:44 AM
The spacers would be on the piston pins, on the pressure side of the pistons, in the 1-2 and 3-4 accumulators on the TH700R4 - also many B&M shift kits have you drill the separator plate and replace a spring in the pressure regulator (front pump) on my car this caused the regulator to 'buzz' when cold at idle in gear - sounded like a bee - another thing to look for is the absence of a spring behind the Modulated Throttle Valve Upshift valve (at the FRONT of the valve body, second inboard from the passenger side). Those spacers in the accumulators are bad - it's much more preferable to go with stiffer springs as opposed to the spacers.
Another BAD thing about the B&M kit is that on my transmission, is the way the 2-3 shift on my transmission was modified - it sure does pound into 3rd but I think it releases the 2-4 band first ... before the 'slam shift' the engine flares during the shift and this can never be good.
FormulaLT1
08-27-2006, 11:47 AM
The spacers would be on the piston pins, on the pressure side of the pistons, in the 1-2 and 3-4 accumulators on the TH700R4 - also many B&M shift kits have you drill the separator plate and replace a spring in the pressure regulator (front pump) on my car this caused the regulator to 'buzz' when cold at idle in gear - sounded like a bee - another thing to look for is the absence of a spring behind the Modulated Throttle Valve Upshift valve (at the FRONT of the valve body, third inboard from the passenger side). Those spacers in the accumulators are bad - it's much more preferable to go with stiffer springs as opposed to the spacers.
I couldn't think of the name of the housing for the piston :banghead: and so I had a brain fart :uhoh: and said valve body but your right.
Jcrane88
08-27-2006, 11:49 AM
sounds like a pain.....i dont have a buzz.. i suspect cause the shifts are a bit delayed and there very hard.....on gravel the 1-2 shifts is so hard it spins the tires and gets me sideways...i changed the fluid and filter a few weeks ago i didnt notice anything out of place....it did seem extremely clean for a 1986 transmission...clean enough to eat off it..if it wasnt covered in dexron
silicon212
08-27-2006, 01:16 PM
If you're worried about that hard 1-2 shift (it COULD, after all, end up breaking the reaction sun shell causing failure of gears 2,4 and Reverse), you can drop the pan, remove the 1-2 accumulator housing (three bolts, one long and two not-so-long - all 10mm head size) and check to see if there's a spacer in there behind the piston (which should come out by tapping the housing, inverted, lightly against a wood block a few times), remove it. If you have a white spring in the accumulator along with the spacer, removing the spacer will soften the shift a bit (still firm, but not 'let's now break parts' firm). If you have a purple spring and the spacer, remove spacer and throw away purple spring, replacing it with white spring. If you have an orange spring, replace this with a white spring to soften the shift a little (as above).
If you have a purple spring and a spacer, you can remove the spacer, flip the piston upside down and put it back together to give a good shift until you get a white spring.
The purple spring alone will give a very soft, baby-butt soft, almost sloshy 1-2 shift which a lot of people prefer, but it's not good for the transmission (for obvious reasons).
Jcrane88
08-27-2006, 02:07 PM
im dont have a problem with the shift unless its gonna break things. the car used to be a 1/8 mile warrior before i got it..so a shift kit wouldnt surprise me...id just like to know
Jcrane88
08-27-2006, 02:08 PM
btw are you a tranny expert?
silicon212
08-27-2006, 04:46 PM
I know my way around them, but as for the TH700R4 I'm totally in learn mode right now as I have three of them in various states of repair (one of which is in my car).
