AIR DRIED BEEF DOG FOOD
1971 Pontiac LeMans 455 cu. in. engine
arlp
08-25-2006, 11:10 AM
Anyone know how to set timing? Thankyou.
maxwedge
08-25-2006, 04:49 PM
Disconnect vacuum advance get a timing lite on # 1 plug and set the timing as desired, also set the point dwell to 30 degrees first.
arlp
08-25-2006, 08:53 PM
I was told to set at 12* before TDC.Does anyone know at what RPM?
maxwedge
08-26-2006, 09:49 AM
500 rpms, but at 12* setting if this is a high compression 455 it will ping on regular, also for daily driving you will need lead additive if the valve seats are stock.
