Rough idle
BlazinMlew
08-22-2006, 12:41 AM
Well heres the problem.
Right after I start the blazer I feel a little bit of a rough idle. If I try to go right after I start it it seems to just bog way down to the point of almost backfiring. If I let it sit for a minute or two though it runs much better.
I am in dire need of a tune up so I am thinking that would be some (most) of the cause, any other thoughts, comments?
TheBrettster
08-22-2006, 01:00 AM
I would love to see what your cap and rotar look like.
BlazinMlew
08-22-2006, 07:53 AM
As soon as I do the tune up I will get pics of the cap and rotor and the plugs so you all can take a look. I am pretty sure thats whats causing my problems. I just wanted some more input from everyone.
danniobrien
08-22-2006, 08:26 AM
I had a similar problem and the check engine light was coming ocasionally. I ended up needing to replace the TPS and air filter.
TPS cost 26$ and the air filter cost 10$
Did it myself took about 30 minutes total.
Good luck!!!
