Over Clear Coated, what do i do?
Shaguar47
08-15-2006, 08:12 PM
Hey guys, been a while since i've posted here. Well i figured since you guys know your stuff really good, i need help. This is for an si grill i'm painting for my 99 civic. Problem is that i over clear coated it too much and now the color is not as crisp or clear as it used to be. It's just coated too much and looks dull. What can i do to undo the clear coat?
YZ125rider21
08-15-2006, 08:50 PM
you can try to wet sand it or what I would do is a shit load of buffing and should see some progress but my step-dad a professional air brusher so I ask him and get the right answer you want and not hear-say shit
Shaguar47
08-15-2006, 08:52 PM
Please will you! I would appreciate it greatly!
TheSilentChamber
08-15-2006, 09:07 PM
Hit it with some 600, work your way up to 1500 (or 2000 if you want) then go over it with some fine cut rubbing compound.
Also let it cure for about a week and half before doing this, if you dont you'll clog the shit out of the paper very fast.
maxassassin
08-16-2006, 01:31 AM
1500 shit thats way to fine for his app he needs to wet sand with 400 and then cut and buff that baby and it shoul be fine after that. 1500 is for runs in the clear. not fixing a hole grill.
TheSilentChamber
08-16-2006, 02:16 AM
You dumb fuck learn how to fucking read.
TheSilentChamber
08-16-2006, 02:17 AM
And 1500 isnt for runs in the clear you dumb fucking moron.
mellowboy
08-16-2006, 02:20 AM
TSC knows his stuff Max. He owned a body shop and he does this as a side job/hobby.
Shaguar47
08-16-2006, 06:27 AM
So if sand it just enough to get the last coat of clear off and buff it, it'll look okay? What kind of buffing material should i use and compound?
TheSilentChamber
08-16-2006, 06:57 AM
Wetsand with 600, it will remove the haze (well accually it will look hazier when you finish sanding but thats part of the process) then do it with 720, 1000, and 1500 (you can go up to 2000 if you want, but its probably not going to make that much of a noticeable differnce, just less work with the rubbing compound). 3M makes a rubbing compound that is commonly available at most parts houses in small bottles, get the Fine Cut. Use a terry cloth with the rubbing compound.
Tony
08-16-2006, 05:38 PM
Yep, I agree with TSC on this. It will make it a lot more clear when you get done.
I don't agree with TSC's response to Max..not the tone of it, but he is correct. 1500 is for compound, not runs. If you want to use 1500 for runs, your gonna be there all day getting it out. Just about anytime you want to wet sand and buff, you want to finish up with atleast 1500, 2000 does make it alot easier on buffing, but not necessary.
TheSilentChamber
08-16-2006, 05:42 PM
Sorry for my tone, it just pisses me off when someone skims over a post not reading all of it then replies that your wrong about something that you didnt even say.
Shaguar47
08-16-2006, 08:43 PM
Fixed it. Looks great now. TSC, you still know your stuff man. Awesome. Thanks again guys!
Tony
08-16-2006, 09:56 PM
yea I know the feeling man, just watch the tone next time. Its easy to correct them and not use the language you did, just cool down a bit before you posts, usually helps.
Shaguar, glad TSC got you fixed up.
maxassassin
08-16-2006, 09:58 PM
well im sorry for not knowing someoens life story. hwoever this is my career as well. i may not be as knowledgeable as tsc right now but im sure im only half his age. oh and ps. i didnt jsut skim over the post. thats some serious over kill. my old man would know.
