Problems on Malibu 98 LS to fix??anyone
eddie_g87
08-14-2006, 11:01 PM
1. of all i have a squeaking sound when i press the brake pedal and its not the pads, it sounds (like a spring or something when i step on the brake pedal)noise is outside.:banghead:
2. my drivers front light plug keeps burning (is it true that placing grease on the plugs or switches stops the burning?
electrical):banghead:
3. my transmission sometimes slips when i first acelerate then a hard noise in the transmission occurs and it runs perfectly.(it fixes after transmission slips):banghead:
4.washer fluid is leaking at the bottom of the tank and i dont know how to fix it or replace it.:banghead:
5.water in brake lights keeps going in and messing up the lightbulbs. :banghead:
6.check engine light 02 sensor i replaced already the os sensor from the passenger side and the check engine still comes up :banghead:
7.ac control goes on and off:banghead:
i wont put the brake problem cause i just fixed it.and i know the alternator chirping sound too..but my car needs repair Plz help
PLZ SOMEONE HELP ME FIX THIS :shakehead
porrsher
08-16-2006, 04:26 PM
1. Sounds like the springs in the drums are rubbing/rusty and require a good cleaning
2.Grease will keep it from sticking and somewhat of a water sealer, never heard of it helping to keep it from burning out, are you using the correct bulb?
3.check your tranny fluid. sounds to be low on it and the loud clunk you hear is the tranny catching on, keep doing that and it will only get worst not to mention damaging the tranny mounts.
4.Not sure about that one but do beleive on that model it will be behind the front fascia on the drivers side, the leaking is probably from where the pump is on the bottom and should be fixed with a little J & J weld, a mixing sealan/cement type material that comes in two tubes.
6. I would check the sorrounding of the taillights to find where the water is comming in and seal it with a clear bond.
7. I have read alot about that a/c controler going out and only operating on certain speed, a quick search of the forum should get you the info you need for that fix.
RJ MALIBU
08-21-2006, 06:15 PM
5. For you O2 prob, change your other O2 sensors and have your cat checked.
eddie_g87
08-23-2006, 07:59 PM
thanks alot guys really helped me alot.:rolleyes:
gapboi210
08-31-2006, 12:01 AM
another fix is to take advantage of the 1500 cash back at your local chevy dealership and get a new car. LOL but then again not a lot has changed in the GM v6's, still run hot and not the smoothest refined motors....sigh...when will GM learn?
Blue Bowtie
08-31-2006, 10:41 AM
Do I detect a hint of sarcasm? What is still not working?
...not a lot has changed in the GM v6's, still run hot and not the smoothest refined motors....sigh...when will GM learn?
You really can't condemn all GM V-6s. The Buick 231 is the most envied, emulated, and still the best automotive V-6 on the planet, bar none. The Chevy V-6s do tend to have some issues, but heat isn't one of them. Almost every engine currently produced has a target coolant temperature at or above 220°F.
eddie_g87
08-31-2006, 01:35 PM
no...no sarcasm . the smiling face made it look like one the second time i read the thread :D
