ticking
wykydjuggalo
08-11-2006, 10:34 PM
93 laser 1.8, when the car is idleing it ticks and blows white smoke, it also ticks in first once i get out of first gear it stops and runs fine. it also burns oil what do i need to do to fix it
Killa
08-11-2006, 10:50 PM
your ring worn
Blackcrow64
08-11-2006, 11:00 PM
your ring worm
:rofl:
He means your rings are worn, thats why it burns so much oil and blows smoke... The ticking is nothing more than the lifters ticking due to a lack of oil. It won't hurt anything as all dsm's have this problem. They have a better set of lifters with larger oiling holes that eliminate this annoying sound. I have a new set thats going in my new motor.
gthompson97
08-12-2006, 01:39 AM
To fix it you will probably need a new motor. If it burns oil AND blows smoke then A) worn out piston rings B) bad headgasket C) both A & C. How many miles does the car have? Do a compression test and get us the numbers you get.
talon-95
08-13-2006, 10:50 PM
your ring worn
RING WORM! ? :grinno:
You old Dog! :naughty:
