single carb D15B ---> DOHC ZC
BurgerBoy
08-19-2002, 11:12 PM
Hey all, I've got a single carb D15B in my '89 JDM civic. I'm getting a complete '88 JDM CRX Si for NZ$200. It has accident damage etc so I'm using it for parts.
Anyways, I'm going to put the ZC in my civic. what I want to know is what do i exactly need for the swap? Remember I have everything from the CRX at my disposal.
Because im going from carburetted to fuel injected i know the carbureted versions only have a non pressurised fuel system, so I would have to make it pressurised, and probabaly add a couple of fuel lines as well. I know i also need the ECU (duh! :rolleyes: ), wiring loom and the injector resistor box. Anything else?
Any help would be appreciated. :D
Thanks in advance.
And heres a pic of my car just for the hell of it hehe:
http://g2integra.hypermart.net/af/carside.jpg
BurgerBoy
08-20-2002, 11:38 PM
Well I guess nobody knows anything :D
1990civic
08-21-2002, 01:25 PM
carburetted??????
1990civic
08-21-2002, 02:23 PM
Your Honda Civic Is The Very First Carburetted Enging I Have Ever Seen In A 4th Generation Civic!!!
BurgerBoy
08-21-2002, 05:23 PM
You are kidding right?
When I get home later I will post a pic of the engine.
amy@af
08-21-2002, 06:22 PM
:D EDM rules. my favorite version out of all civics made.
okay, i think i understand. you have what would be equal to our dx. you want to upgrade to what would be equal to our si. your car isn't completely carbed. and it is dual port injection. you want to go multi-port.
you will also need the intake manifold and is suggested to get another stock wiring harness to convert. i have heard people messing their and then been without a car until another harness is found.
there was a how-to article in Sport Compact a couple months ago. I was adding all the info to the Civic site (since a lot of people inquire about this conversion). i'll go finish it and post a link in a couple of hrs.
bracer is my source for EDm info. if you haven't been there before, check out bracer's site (http://www.carpage.tmfweb.nl/civic.htm)
ami
amy@af
08-21-2002, 07:01 PM
okay, info added :jump: go to: how-to's (http://www.4thgenerationcivic.com/how-to's/How-To's.htm) and use the link on the bottom
BurgerBoy
08-21-2002, 08:58 PM
ami
My car is JDM remember :p
But I get what you mean about the dual port to multi port. And that howto is very helpful too.
Keep in mind that I will have the complete CRX with ZC at my disposal, so parts aren't a problem.
And when I starting thinking about this it seemed very straight forward. But the more info I get about it, its starting to warp my fragile little mind :D hehe
BurgerBoy
08-21-2002, 09:04 PM
here's the pic of my current D15B
http://g2integra.hypermart.net/af/civic_motor.jpg
GTA
08-21-2002, 09:19 PM
Heh... Ami... i do believe that is a Carbed engine, not DPFI :silly2: Unless they do a diff setup for dpfi in JDM cars.
EF6_CR-X
08-22-2002, 05:09 AM
It might pay to try and get some info from someone who has done a carb to injection swap, it might get quite complicated.
I dug up some tech diagrams I had, here are the ones for the JDM 1.5X Dual Carb CR-X, and for the Injected CR-X. As you can see there is quite a difference, and the crx ones will probably be shorter than for the Civic. :mad:
The carburetted 1.5X
http://files.automotiveforums.com/uploads/84301615xfuellines.jpg
The injected Si
http://files.automotiveforums.com/uploads/926592SiFuellines.jpg
Probably there only US people who can help would be the ones who have converted a Carburetted 1g CRX or 3g Civic to injection.
Or alternatively you could get the Carburettor, and an ECU from a JDM 1g teg with the Carbed DOHC ZC, but then you'l only have 120hp. :(
Setanta
08-22-2002, 07:23 AM
You need everything - dashboard forward (and the fuel pump etc).
Sit them next to each other and swap away ;)
You'll need all the sensors etc, but it should all bolt across.
Now if I only had a pic of the twin-carb D15B engines - computer controlled setup - damn it's nice and works a treat. 100bhp from a 1500 that we got over here :)
EF6_CR-X
08-22-2002, 07:54 AM
I should have a pic somewhere :D , I've had my JDM twin-carb D15B CRX for about 3 years now, and still love it, its just right if you're after a good compromise, and of course being JDM they gave themselves a few extra hp to make it 105hp.
BurgerBoy
08-22-2002, 07:22 PM
Thanks for all the info so far guys. I really appreciate it.
And its a shame you guys don't live near me cause then you could help me with the swap mwahaha :devil: :D
And I'm picking up the CRX this sunday.
I'm as giddy as a school girl <-- ok wrong comment to use :bloated:
amy@af
08-24-2002, 07:12 PM
sorry! for some reason i thought it said you were in neatherlands... :apoke: i must have bumped my head :D
BurgerBoy
08-25-2002, 12:41 AM
I am Dutch cause both my parents are dutch and come from the Netherlands, but I live in New Zealand :D
And on another note, I picked up the CRX today :D :D Had to drive 3hrs to go get it though :rolleyes: . But it was worth it cause it was originally NZ$200 but i managed to get it for NZ$140
MWAHAHAHA :devil:
DarkImportGrey
08-25-2002, 02:13 AM
i've never heard of a carb to injection swap on a civic... i've seen it done on a lot of big domestics (350 chevy small block is common)... but never on a 4 cyl.... it might not be easier, but i know you could find a lot more information about doing a whole engine swap than to do a carb to injection swap.
BurgerBoy
08-25-2002, 02:20 AM
I am going to do a whole engine swap, hence the title of the topic. And I have a fair bit on info on the swap so far.
BurgerBoy
08-26-2002, 02:21 AM
well heres a pic of the ZC :D
http://g2integra.hypermart.net/nzhondas/crx/crx_zc.jpg
Still need to take it out of the CRX
Try and see if you can guess what missing...... hehe
