radiator crack
finlax97
08-10-2006, 11:55 PM
I have a crack in the top of my radiator about 5 inches long. it only leaks when the engine is hot, but i constantly have to refill the reservoir and radiator almost every other day. i tried to fix it with some stuff i found called quickSteel thats supposed to be temp resistant to 600 degrees. i tried to seal the crack with it with 3 layers and the crack reopened... does anyone have any ideas on what else i can try to seal the crack??
rodbls
08-11-2006, 08:05 AM
Well, the old trick of using an egg white only works with pinhole leaks. The same goes for any commercial product that seals radiator leaks, they can only be so big. A 5 inch gash, no matter how thin, will not heal with these products. Looks like a new radiator is in store for you bro...sorry.
808drifter
08-11-2006, 09:39 AM
yep, and if you have the means/$$$ get a good aluminium one if you feel like upgrading.
