raise my window from the dead
stone_mound_camaro
08-09-2006, 08:06 AM
My switch on my driver side power window is worn.... The motor isnt bad, just the switch. It no longer works and I'm going back to school with my window stuck open. Is there a way to get in there and manually push the window all the way back up? thank
~Lex
~Lex
wrightz28
08-09-2006, 09:17 AM
Run battery power to the motor. it's a reversing motor, so one connection will put it up and the other will put it down.
stone_mound_camaro
08-11-2006, 11:42 AM
ok...well how do i get power to the motor?
wrightz28
08-11-2006, 12:10 PM
Run battery power to the motor..
Remove the panel and go forth in sin.
ikeyballz
08-11-2006, 06:21 PM
or, if youre sure its just the switch take the wires from behind the switch and short em out in the way the switch does to make it go up or down...
