They say I threw a rod
driftkid21
08-07-2006, 04:25 PM
I have a 95 Eagle Talon front wheel drive 2.0 DOHC non turbo motor with a air intake that drops down in the front of my tire. I got caught in some heavy rain and my engine got flooded. When I started it the engine had a knock, it still runs but I dont drive it, my mechanic said that I threw a rod but it might be repaired, should I repair it or spring for a new engine, or may it be something else causing it to knock.:banghead:
nova1313
08-07-2006, 04:44 PM
are you sure it's just one cylender? If you sucked water into your engine picture it like a soda can. When the cylender compresses it the water has to go somewhere. It either blows a piston or a valve (in a soda can it usually blows a hole somewhere). If it's not too much damage I'd say have them repair it..
It's really up to you depending on the extent of the damage. But they won't know unless they open it really.
Blackcrow64
08-07-2006, 10:21 PM
If it did throw a rod you might be able to just fix it. You would have to bore out the block and get a new set of rods and hopefully thats all. It really depends on the extent of the damage.
Thor06
08-08-2006, 03:18 AM
Take the shit apart and assess the damage. To me, if you "threw" the rod, it went out the side of the block and your shit is pretty fucked up. If its just a rod knock if you are uber lucky, its a just a set of bearings. If bad luck, you may need a new block, crank, and set of rods on top of the gaskets and bearings.
Oh yeah, welcome to the club. ;)
driftkid21
08-09-2006, 04:50 PM
I appreciate the help everyone has given me. Hopefully my car wont be out of commission for long, thanks again and dont forget to show the police what speeding really is:thumbsup:
Killa
08-09-2006, 05:13 PM
I think it time for you, to move to turbo world. Dont wast money repair it. Donate that car to junkyard or something :wink: .
