how you do boost leak test again ?
Killa
08-07-2006, 01:46 PM
Im very confuse right now, I build a boost leak test ( www.boostpro.net ) is POS. any way I take off the intake from the turbo, and hook up the test to it, what else do I have to take off ? thanks.
crunchymilk55
08-07-2006, 01:55 PM
nothing, pressurize the system with air. the 12 volt crappy air compressors don't work, use a gas station or a real air compressor. Listen for leaks and spray areas with soapy water, they will bubble up if there is a leak
Killa
08-07-2006, 02:26 PM
I bought 7 galon air tank from walmart, any way I spay load shit of soup, and found buble from the bov return nut,the line that go into your manifor. and found load shit of air come out from oil dip stick ( my dip stick broke between the metal to the blastic handle ). I need new oil dip stick.
