AC Blower fan wont shut off. HELP!!
croozer
08-06-2006, 10:08 PM
Hi, Long time no see. I ran into a problem tonite, I shut my 95 JGC off and the AC blower motor stayed on and the ac switch says "Er" Is there any fix I can do for this or has anyone had this problem? Thanks guys, You have been very helpful in the past and I have given advise too. This one has me stumped for now.
fordin K
08-07-2006, 12:33 AM
find the blower motor fuse some where and pull it out. for now
croozer
08-07-2006, 10:16 PM
Thanks for your reply, I found and repaired it.
bringselpup
08-08-2006, 08:11 AM
What did you do to fix it?
croozer
08-08-2006, 09:16 PM
It was the fan resistor. Part # 4720046. It was easy to replace, I read the schematic and followed the circut to the dead resister.
spielightdude
08-09-2006, 02:14 PM
Granted this is based on a 1996 jeep cherokee sport model with the 4.0.
Anyway I had a similar problem and for 3-5 relays they were defective and would get stuck closed and so the fan would run. I had to pull the relay from the fuse box in the eingine compartment but after I got the 5th relay it works fine and that was 3-4 years ago. Also after having to replace the relay so many times after the 3rd relay the dealer did not charge us for #'s 4 and 5. Just in case it happens to anyone else it may also be that.
croozer
08-10-2006, 08:23 PM
On the 95...The relays have no effect...You pull em and it still stays on. It was the resistor modual down by the heater fan motor.
spielightdude
08-10-2006, 09:05 PM
Thanks Croozer good to know.
I just hope that with my soon to be 1997 JGC laredo model doesnt have any problems like this :o)
