Absolutley No Spark At All
blazin911
08-06-2006, 08:45 PM
Well Fellas Im Back With A New Problem, Or Maybe This Has Some Connection With The Last One, I Was Driving And The Car Turned Off, Checked For Spart At All The Plugs And At The Coil And Nothing Could It Be The Ignition Switch I Mentioned In One Thread That My Column Cover Was Missing And My Key Hit The Box Below The Key Cylinder And It Sparked But No One Replied, What Do You Guys Think, Infinit Thanks And Blessing To All
internic
08-07-2006, 04:40 AM
see if the coil gets 12 volts when the key is turned to "on"
muddog321
08-07-2006, 05:31 AM
Check the fuses first and see if you blew one or more. Could have a short in there still. Post year.
blazin911
08-07-2006, 10:54 AM
fuses are ok and yes i have 12 volts to the coil theres no spark from the coil all the way through to the spark plugs
could a bad ignition switch cause this problem
its a 95 blazer vortech with side mounted spark wires 4.3
Rick Norwood
08-07-2006, 01:13 PM
When my 93 did this, it was a bad ignition module in the bottom of the distributor. Not sure what year they stopped putting the ignition module in the distributor, but it can be removed and bench tested at some of the better parts stores.
blazin911
08-07-2006, 07:44 PM
i already switched that piece and nothing happened
BlazerLT
08-07-2006, 08:36 PM
Coil would be the first thing I would look at.
blazee
08-07-2006, 08:42 PM
blazin911,
Earlier today, I sent you a PM politely reminding you that bumping threads and back to back posts were against the rules. I also explained how to use the edit button and sent you a copy of the Community Participation Guidelines (http://www.automotiveforums.com/vbulletin/guidelines.html). So far in this short thread I've had to merge 3 of your back to back posts, and remove 5 pointless posts that only served to bump this thread. If you can't follow the rules, I'll have to lock this thread and you'll be unable to start a new one.
