lowering a 4x4?..
A_State_Balla
08-03-2006, 07:09 PM
ok heres the deal im thinking about lowering my 88 4x4 s-10 blazer but im not sure if i should im also wanting to put some rims on it but im not sure what size to put on it i was thinking 20" but im not sure if i can lol well enywayz im a newbie sumwhat so any help would be great thanx a lot!
-D-
BlazinMlew
08-03-2006, 10:19 PM
Do a search on it. You should find some info to help you out.
I know that it has been said you are going to wear you ball joints out much faster with it lowered. So thats something to think about.
OverBoardProject
08-03-2006, 10:39 PM
Personally I'd just get a 2wd frame for it and sell your rolling chassis
I understand that the only difference between a S10 and a S10 Blazer frame is the center cab mount which is 3" taller or shorter.
Although I've never looked at the 2 frames side by side.
rlith
08-05-2006, 06:30 AM
There are a lot of good resources for lowering 4x4 trucks, be it just blocks or bagging..
pimprolla112
08-05-2006, 11:22 AM
Blocks or leafs in the rear and torsion bar tensioner bolts in the front you can do 2/3 drop i believe. Ive got 2"blocks int he rear i havent had time to get to the torsion bars. ANd i can fit 20" wheels with a 245/35/20 tire on the blazer. the tires will only be 26.7" tall.
