94 Door Panels
MikeyV411
08-02-2006, 03:20 PM
How ya'll doin? I'm trying to take off my front door panels to replace the speakers and I know you hafta remove the 2 screws and then pull the door to get those plastic connectors out but I cannot seem to manage to get the door off because the door handle. How do i get around this problem? The door handle blocks the door from coming off. Thanks fellas.
acidcrashdburnd
08-04-2006, 01:06 PM
there is three screws the third one is on the little plastic panel by the handle be easy when you take it off the little yellow connector things break easly
MikeyV411
08-05-2006, 07:15 AM
Where are those three screws located? And if anybody knows the answer to this I'd appreciate it too. I found out there is also tweeters connected to the 5 1/4's. If I disconnect the tweeters will it do anything or if I reconnect the tweeters to the new speakers what will that do? Thanks guys, I'm a rookie to this game and just trying to learn.
acidcrashdburnd
08-05-2006, 10:28 PM
well your first 2 screws are right in that little thing you grab to pull the door cloed then the 3rd screw your looking for is right next to the door handle then after that pry off the cover with the power door lock button on it and disconect the wires on it then your gona disconnect the window control(s) switch pry from the top with a screw driver then go from there and btw i still have the factory tweets in my front doors helps the sound out but i put 6in 3 way boston acoustic speakers in the fron mmm dremmel :)
acidcrashdburnd
08-05-2006, 10:46 PM
http://i29.photobucket.com/albums/c289/vacidcrashdburnd/thingtoremove.jpg
thats the third screw pry that out and your good to goooooo
MikeyV411
08-08-2006, 12:22 AM
Hey Thanks a lot man. Should I replace the tweeters or no?
MikeyV411
08-09-2006, 06:44 PM
Actually I said thanks prematurely. Theres definately no screw behind the handle in my 94' Oldsmobile Eighty Eight Royale. More help guys. I appreciate trying tho.
acidcrashdburnd
08-17-2006, 05:07 PM
thats odd your car is only one year older then mine. hmmmmm well you could buy something from crutchfield they give you step by step instructions on how to do it :) take a picture i would like to see this set up .....
jimberg98
08-18-2006, 09:27 AM
Use something like a small, flathead screwdriver to pry out that little panel from the top. I have a 96 and it simply snaps in.
