how do i start a burnout in a stick shift firebird
uhhidk
08-01-2006, 06:42 PM
i got this 97 firebird but i dont get how to stay with the burnout when im still well powerbraking it like ill go and after like 10 secs ill stop and sometimes i cant start the burnouts without the brakes stoppin the back ones
Mr. Luos
08-01-2006, 07:25 PM
Too much brake pressure.
heidi ho
08-02-2006, 12:17 AM
cant help you, I never had a problem doing a burnout with a manual, or even an automatic
97cavalier
08-02-2006, 01:17 AM
i agree, you hit the brake to hard. IT is tricky to smoke them with a stick holding the brake. you have to work on it, and get the right touch.
97cavalier
08-02-2006, 01:18 AM
they also sell kits that you flip a switch inside your car and it will only lock your front brakes up. that will help alot.
hotrod_chevyz
08-02-2006, 06:39 AM
Maybe its not very strong.
ikeyballz
08-02-2006, 07:45 AM
be on the brake JUST enough to NOT move.. but not enough to lock the back up.. or get wheel chocks. ;D
importeater38
08-03-2006, 08:32 PM
lol @ wheel chocks! lol... why does the term "trailor park" come to mind?
2000LS1Z28
08-03-2006, 09:31 PM
Had the same problem. I ended up starting the burnout and slowly applying brake pressure. If you do it right the car will only lurch forward a tiny bit, and then just sit there and peel out.
Not a good idea to do with new tires.
goldz28
08-05-2006, 07:57 AM
Curtis
How did you do the 4th gear burn out in your car? Line lock ect???
Mr. Luos
08-05-2006, 09:14 AM
Linelock.
http://www.arbybean.com/ar/images/Linelock01.JPG
My little switch...
http://www.arbybean.com/ar/images/Linelock03.JPG
goldz28
08-05-2006, 09:39 AM
The secret is out on Mr. Luos burnouts....lol. That is a good spot for the switch. Out of sight out of mind...
Mr. Luos
08-05-2006, 09:29 PM
Was never a secret. :wink:
2000LS1Z28
08-05-2006, 09:41 PM
I can tell that Luos doesn't smoke.
Mr. Luos
08-05-2006, 09:50 PM
Used to.
Over 4 years ago though.
phrozey
08-14-2006, 09:41 AM
you chain your car to a poll and floor it....duh
SLP linelocks also works like a charm ;)
hotrod_chevyz
08-14-2006, 10:33 AM
Heck push the clutch in, put it in first, and run the tach up to about 3500-4000 rpm's. Once you have the rpm's running steady, slide your foot off the right side of the clutch pedal and quickly land the foot on the brake pedal. As soon as you have your foot situated, push the skinny pedal on the far right all the way to the carpet. Betcha it'll peel out then.
MY 87' 2.8v-6 5spd. sure would. After it was totalled out in the front end, thats how i sold it. It burned the tires off for like half a block on an incline, right after i smoked the tires for 15 seconds standing still. As it was peeling out, i had time to take a drag of my cigarette, and ash it calmly out the window. The guy buying it said " dang ive never seen one of those do that before". All it had was some flowbastards and a K&N air fliter.> He never payed me the rest of the money for the car, so I sold it for scrap eventually. The last time i saw it, it had a volvo parked on top of it.
giddyup50
08-20-2006, 09:53 PM
I love that warning sticker. Where can I find that but, instead of saying Firebird, I ofcourse need it to say Mustang? I don't care if it is a real sticker or if I have to print it out on the computer/printer. Just as long as I can find that or even better ones out there. Thank You.
phrozey
08-21-2006, 09:26 AM
But the sticker says that the car accelerates fast..:grinyes:
