Possible Caliper Probelm?
AphroditeIncubus
07-24-2006, 03:36 PM
I have a 99 and the front right wheel squeaks as I am driving. I can turn left, right, doesn't matter. It doesn't always do this either. Usually when I hit the breaks it stops. Could the caliper need replacing? The last time I got the brakes changed, I only needed to replace that particular side because it had wore all the way down to the metal. Any help or advice would be greatly appreciated.
BNaylor
07-25-2006, 06:29 PM
Post moved from Alero to the new "N" Body Forum due to lack of a timely response.
maxwedge
07-25-2006, 07:16 PM
Due respect here, but common sense says have the wheel removed and look at the condition of the pads, may be the wear indicator as the symptoms say the pad is on the wear indicator.
speedracer989
04-15-2007, 11:19 PM
I had a similar sounding problem and it ended up that the right front caliper wasnt releasing all the way. Changed out both calipers, got some new rotors and pads, now the sound is gone and the brakes work great.
xeroinfinity
04-16-2007, 08:56 AM
Welcome to AF speedracer989.
Please look at the threads dates, as this one is outdated.
We dont bring up threads older then 3 months :grinno:
Please read the Community Participation Guidelines (http://www.automotiveforums.com/vbulletin/guidelines.html)if you havent already it explians it all!
this is closed!
this is closed!
