heat from turbo
buckchuck27
07-22-2006, 09:45 PM
my turbo heats up the engine bay severely and i was wondering if anyone else has this problem and what they did about it. and also would a tubular exhaust manifold keep things "cooler" compared to those cast iron dsm ones?
Sleepr awd
07-24-2006, 01:08 AM
the heat is pretty much something you have to deal with. try some "water wetter" available on roadraceengineering, as well as an adequate intercooler for the setup, but otherwise, turbos will always heat things up.
what is your setup? stock 1g on a GS ??
a better radiator
also staying out of the boost will help, i kno, it is tempting
a better radiator
808drifter
07-24-2006, 04:02 PM
or you can also heat wrap the headers and anything else that puts off heat.
buckchuck27
07-24-2006, 06:44 PM
i got a 14b with the stock manifold on a rs. and as of right now only running 5psi cuz i dont have money for the tuning to go higher.
o and another thing, my fan will not shut off. like as soon as i turn my car on it starts blowing, and stays until like 10 seconds after i shut my car off.
Sleepr awd
07-25-2006, 05:46 AM
oh yeah, oil cooler
definitely get a intercooler though, and it shouldn't do that AS much, but it won't "cure" your problem. your best bet is to try everything possible and that may cure it.
rodbls
07-25-2006, 07:48 AM
I've heard that the Evo style hoods help vent the engine bay (may or may not be true). I would assume it is true because it has vents in it to help more air into the bay. Could help out, and also would look pretty good.
buckchuck27
07-25-2006, 10:13 AM
yea i have both intercooler and an oil cooler (cut those plastic things out from under ther corner light for the oil cooler). and i was tryin to find if i could buy the vent from an evo hood and just cut a hole and mount it on my hood cuz i dont feel like spend 400+ on a hood.
brad02420
07-26-2006, 12:02 AM
That would be sick.
That would be sick.
808drifter
07-26-2006, 02:27 PM
with a hood like that the best thing to do is duct the air through the frnt bumper and direct it up through the hood vent.
Andrw912
10-25-2006, 11:53 PM
I have a t3/t4 in my gs, it use to heat up alot also. I setup for my fans to stay on at all times, it really helped keeping my temp down.
Sleepr awd
10-26-2006, 01:30 AM
also try a colder thermostat, and what he said
the evo hoods helped i believe it was 10-20 degrees fahrenteit.
also more efficient fans could help,
