Oil Catch Can
dlstewart01
07-18-2006, 10:44 AM
Is any body using an oil catch can on their truck? It is hooked up between the pcv and intake to remove oil from the system.
Does it work?
Any problems with install?
Any noises like air leaking.
What brand used.
Thanks and have a great day,
Don:)
Slowprocess
07-19-2006, 02:39 PM
Does it work?
What brand used.
Don:)
It does work. That's one major flaw to these GEN3 engines.....excessive oil consumption through the pcv setup. It definately works to keep oil from getting into the intake and combustion chambers. This cuts way down on the carbon buildup on the intake runners, combustion chamber, etc.
Install is straight forward. No noise or other problems.
AMW makes an awesome kit. Pricey but really clean.
Another way to help with this problem is to use an ls6 valley pan, which removes the pcv in the valve cover and moves it between the intake and valley pan.
This will not eliminate the problem, but will help tremedously.
dlstewart01
07-21-2006, 09:26 AM
I installed the AMW catch can yesterday. Everything hooked up real well. Seems to function perfect. hope this keeps the 5.3 clean.
Don:)
silverado122775
07-21-2006, 02:34 PM
Does anybody have a link to that site where I can take a look at the AMW catch can?
Slowprocess
07-21-2006, 04:14 PM
http://www.accmachtech.com/pcvcatchcans.htm
dlstewart01
07-21-2006, 07:28 PM
Right now the only people that have these catch cans is Midwest Performance & Development. Their web site is www.MidwestPD.com
They are located in Ohio. They usually don't answer the phone but you can email them with your phone # and they will get back to you fairly quickly.
They have silver and black cans in stock. No one else that I can find has them. I have done business with this co. a couple of times with good results. Their shipping is low and super quick.
Almost forgot www.eliteengineeringusa.com is working on a catch can for the LS1 engine. Should be ready in a couple of weeks. It is going to be cheaper than the AMW can
Have a great day,
Don:)
silverado122775
07-24-2006, 11:52 AM
Thanks guys
