Setting ignition timing with an aftermarket UDP
Thor06
07-14-2006, 05:13 PM
Hey all, the ignition timing is off on the Talon and I want to set it right. Well, on vfaq they say to look at the tick mark on the pulley, paint it white and point the light at it. Well, I have and aftermarket pulley so what do I do? Where is the tick mark in relation to everything else so I can just put my own on? Any advice or info?
SLoe
07-14-2006, 05:24 PM
I haven't looked, but TDC is TDC (0 degrees) and I would think that is where the tick (TDC) should be. So put it at TDC, and make your tick mark on the pulley where 0 degrees is indicated. I could be wrong, I don't have a 1g, but I bet I am right cause a motor is a motor.
Thor06
07-15-2006, 02:19 AM
So just make the paint mark on the very top of the pulley when its at TDC and play with the CAS until the paint line is even with the 5 on the timing cover right?
SLoe
07-15-2006, 01:00 PM
. Pm sent.
. Pm sent.
kjewer1
07-16-2006, 02:02 AM
Hopefully the PM sent involves something a little more scientific than just painting a line on the top of the pulley :yikes:
There better be a mark cut into it, just highlight that with some whiteout or something. I usually end up using something like my sister's nail polish in some funky color like silver. :icon16:
Setting timing is an exact science, and not something you want to half ass.
SLoe
07-17-2006, 06:46 AM
If there's no mark cut into the pulley, then options are limited. Either the stock pulley would have to be put back on, or one would have to do what I described. :dunno: It should be really close IMHO, it is on a chevy anyway :icon16: Too bad you can't put some timing tape on there.
I would like to know what brand pulley that is. I've never bought an aftermarket pulley for anything other than a chevy, and it just seems a little shitty there is no timing mark on it.
Thor06
07-17-2006, 08:03 AM
Its a Bomz one, cheap as hell on eBay. The may be a tick mark, but I dont remember seeing one...
SLoe
07-17-2006, 08:57 AM
I would take a second look at it :2cents:
kjewer1
07-17-2006, 09:16 AM
The only way I would do it if there is no mark is with a piston stop and a cam degree wheel. But that's more involved than I care to post about. I think swapping the stocker in temporarily would be the best option.
Also make sure that whatever pulley you use is also a harmonic damper. One particular tuner shop in the BMW world found that non-dampened pulleys increase the frequency of thrust bearing wear and other crank related problems. Like many other CW theories, there is no solid proof, but why risk it?
