Extra Heat
poormillionaire2
07-13-2006, 04:54 PM
I was driving today in 90 degree weather when I noticed that my legs were getting hot. Hot air was blowing on them from under the dash. The vents were off and I even had the temp knob all the way in the blue. I stuck my hand under there and figured that it was coming from the lower vents. Now, I did notice this in my other Z. Is this normal? Is this just an extra way to alleviate engine heat? I don't think the vent is stuck open because when I used the A/C, no air came out from the bottom. I'm not too worried, just curious.
NINÅ
07-13-2006, 08:59 PM
Due to the fact both your cars act this
way we will assume your diverter valves are OK
When you have the mode slider to ‘OFF’
air still comes thru. Because the AC was off
the heat of the day was warming the innards
rendering hot air. If you find this annoying
move the slider to ‘VENT’
Happy Racing !
If people drove any slower they’d be going backwards
http://i57.photobucket.com/albums/g214/NINALEEANN/NINAsDIRTCARDECALNUMBER21.jpg
ikeyballz
07-14-2006, 03:49 AM
okay the problem with our car...is that the exhaust system looks like a freakin afterthought. its like GM wanted our car to run cutouts..
the exhaust pipe is so close to the body that they actually had to make a dent in the passanger side seat to fit a cat convertor.. i noticed that from the passenger side, the heat is really bad.. (From the exhaust) if you drive for maybe 1-2 hrs, and feel the passanger side seat..its really really hot.
i think thats the heat you're feeling, i also get the heat to the driver side too..thats prolly just straight through the firewall.
ikeyballz
07-14-2006, 03:50 AM
btw, this is assuming you were driving for a while before you noticed... it should be cool for the first 30 min..(at least mine is..)
wrightz28
07-14-2006, 09:44 AM
Even tho the selector is on "cold" all that does is close the blend door off from the heater core. However hot anitfreeze which is what provides the heat when the blend door is set to "hot" is still flowing through the heater core.
Savage Messiah
07-14-2006, 11:31 AM
The short answer is it's normal, lol
wrightz28
07-14-2006, 11:43 AM
true, but a little expination can either help understand the issue, or reveal that it may not be the cause after checking it out.
poormillionaire2
07-14-2006, 07:13 PM
That's kinda what I figured. I didn't think anything was broken, just curious.
I have noticed that the passenger side does get really hot after a while of driving. I honestly think GM did a crappy job putting these cars together. Some of the shit is tough as hell to get to and work on. Just frustrating.
Thanks guys.
wrightz28
07-18-2006, 09:35 AM
You might have a binding cable on the blend door if it's really, really bad. But yes, never been in a GM sports car that wasn't roasting your feet off on a hot day.
