stereo
95firebird
07-13-2006, 04:04 PM
when i turn my headlights on my stereo goes off why is this i undid every thing to see if wires where toching or somthing but nothing is thanks
CreepingDeath94
07-13-2006, 04:40 PM
you probably have the stereo grounded to the illumination wires for the stereo...check that out first.
95firebird
07-13-2006, 05:14 PM
what do u mean by that??? i unhooked the thoses wires and now every thing work but no parking like how do they get hooked back up
CreepingDeath94
07-13-2006, 06:42 PM
basically, if youre ground wire for the stereo is wired to the wire that is hot when you turn your lights on, it will pop a fuse every time you flip on your lights. There are wires for the illumination of the stereo that need to be hooked up to the illumination wires for the stereo of your car. The ground needs to be hooked to just that, a ground. If there is no ground wire evident, run a wire to ground yourself so you know for sure its a ground and not something else like power antenna or whatever else.
