Jaguar S-Type
xpeed
07-13-2006, 01:27 AM
This is my Maisto Jaguar S-Type. Had it for four years and it's showing age. I realized today that there are scratches and hicks here and there, a cracked windshield and the grille is cracked and splitted and loose from the hinges. I also forgot that I lost a taillight from a vacuum accident.
The only mod I did on the car is lowering it. That's about it and boring out the exhaust. If you don't know, Maisto exhausts aren't bored out. It's covered, so I usually either drill or bore it out to give it a realistic effect. :grinyes:
Other than that, you can see my process in restoring it. Gonna repaint it and replace some parts. It'll be a slow process and I'll post it up here as the progress goes by. I just started sanding off the paint starting with the trunk area.
http://i8.photobucket.com/albums/a48/xspeed/jag.jpg
http://i8.photobucket.com/albums/a48/xspeed/jag2.jpg
nosliw2004
07-13-2006, 04:57 AM
first of all why are you showing us the pics in balck and white? 2nd of all why do you want to restore this? if you replace the parts that means that you'll have to buy another brand new car just for those parts (unless if you have the donor car in stock)
G-man422
07-13-2006, 08:12 AM
Good luck, thats going to take some work. keep us posted.
xpeed
07-13-2006, 01:45 PM
:D I'm restoring it because the paint's all chipped off and scratched. I'm gonna try to find a old damaged S-Type for parts. The picture are in antique color because it's the best resolution my phone camera can take. The normal color mode gives off too much glare. Until I get a digi, this is all I can offer. :(
Rob 01
07-13-2006, 04:27 PM
That looks like a good project car, first of all you can easily get wheels off any other Maisto car , second of all all the parts come straight off the car pretty easily.
This might be a pretty cool car when it's finished!
ClearHooter
07-23-2006, 12:27 AM
I might make a suggestion that would save you some time, elbow grease, profanity and come out with a better overall job in the end. Take the car apart down to the basics and strip the metal with Kleen-Strip Aircraft remover. If you live in the USA you can get a spray can at any "WallyWorld" auto section or for that matter any auto parts store worth its salt for about $5.00 a can. Being that its metallic silver or blue it may be harder to come off and may still require some sanding. But be assured it won't be nearly the pain in the butt that just straight sanding will be. Afterwards prime it and paint it what ever color your heart desires. I use Krylon Gray Primer and if I use enamel (my other choice being fingernail polish NEVER acrylic) I usually bake it in the oven at 400 degrees F about 80 seconds. Then in a couple of days clear coat it with Krylon Triple Clear Glaze. Granted I only work on 1/64 and 1/43 but the principle's the same.
Legolas PT
07-24-2006, 01:03 PM
i think the harder part is to get the light that its missing :(
xpeed
07-24-2006, 03:02 PM
Yeah, I'll put that aside for now and replace it when the time comes. For now, I already sanded down the paint to it's original aluminum metal.
I'm gonna prime it gray for now and paint it to dark blue (navy)
From a beige gold to dark blue is a pretty nice color for this car. :) Pictures will come soon.
Legolas PT
07-25-2006, 05:24 AM
it will be looking great.then paint the interior in camel look...
i have that model too and love it =)
xpeed
07-25-2006, 12:39 PM
:) Sorry, the interior is painted black. I want it to look more VIP. Rims are still debateable, and I'm trying to figure out where I want the chromes. I'll have pictures coming soon, along with my new project. I'm working on two cars at the same time so it's taking some time.
xpeed
07-26-2006, 12:35 AM
Here's the second coating of the new paint. :)
http://i8.photobucket.com/albums/a48/xspeed/BlueJag.jpg
Edit: I've noticed that there are some splotches and droplets in some areas, so reluctantly, I have to scrape the paint off and resand the whole thing again and start from scratch. *sigh* :banghead:
Anyways, I will have to be careful again, I might have to dunk this whole thing in a pool of paint thinner overnight. Scrape some of the layers off and sand the rest of it off. :eek7::cya:
I'll keep you guys posted.
Legolas PT
07-26-2006, 02:18 PM
looks a nice color but maybe it just have too much paint...no?
m3gtrdawg
07-26-2006, 06:04 PM
Nice color!
ClearHooter
07-27-2006, 01:53 PM
How long does it take to sand that car down to the metal? Is the any paint left on it, at all, when your done?
I ain't got stock in this company or nothin'. But I can Kleen-Strip that thing in 15 minutes and there won't be an extra scratch on the metal nor will any detail in the casting be dulled. And All the paint will be gone.
Unless you just get a kick out of sanding.
xpeed
07-27-2006, 03:28 PM
It took me two hours. Sanding it down with 100 count paper, than to 320 count and then to 600 to smooth out the area even more. After that I prime it gray and wait for a day to dry to see any bubbles or uneven areas.
Now that I'm pissed I missed up, I dunked it in a bucket of paint thinner overnight and the paint eventually just slothes off.
ClearHooter
07-27-2006, 10:46 PM
I take it your outside the USA? If so I don't know the equivilant of Kleen-Strip. But it desolves every paint I've ever put it on in 5 miniutes and leaves NO trace. The exception being the HW's silver blue and their silver. Tough stuff indeed. It does hoxever raise the paint to allow it to be cleaned off with Scoth-Brite and it does take several applications to get all of it. ET of 15 minutes. I would always suggest stripping over sanding as no casting lines are disturbed.
xpeed
07-31-2006, 09:36 PM
Here it is. I'm finally done. Just need to coat once more and replace the grill and find a taillight and it should be a done deal. :)
So, what do you guys think of the new paint?
From a beige tan to Navy Blue
Interior changed from Beige to Black with wood trimming
http://i3.photobucket.com/albums/y78/xpeed/DSC00834.jpg
Exterior
http://i3.photobucket.com/albums/y78/xpeed/DSC00837.jpg
http://i3.photobucket.com/albums/y78/xpeed/DSC00842.jpg
Exterior
m3gtrdawg
08-01-2006, 06:57 PM
pretty cool
Legolas PT
08-10-2006, 04:46 PM
looks odd that painting but in a overall view, looks nice and clean! :)
