engine removal
MMonnier2302
07-12-2006, 07:34 PM
alright
im going to remove the motor out myself, most likely threw the top....
what needs to be pulled and yanked first?,its a 95 Z28 with a six speed.
i have a cherry picker and the nifty thing that turns motor inside the engine bay. I dont want to drop several grand for a speed shop to do it, i would rather give them the motor then the whole car.
help would be greatly appreciated, thanks
FormulaLT1
07-12-2006, 08:04 PM
I take you decided to go out the top?
This is a link I saved to my favorites a while ago about dropping threw the bottom which I haven't attempted yet but was very close and Just used the top method I was use to like 3 times. http://www.michiganspeed.com/enginepull/index.html
MMonnier2302
07-13-2006, 07:10 PM
looks complicated thou
any info on out the top, i dont want to jack the car up that high
Mr. Luos
07-13-2006, 07:13 PM
HEHE
http://www.arbybean.com/ar/images/Swap060.JPG
FormulaLT1
07-13-2006, 07:16 PM
Out the top you need to remove the fans, radiator, a/c condenson, tranny cooler, steering linkage, brake vacuum line, harness needs to be disconnected from all sensors, fuel rail , remove the 6 bellhousing bolts and place a jack with a piece of wood inbetween on the tranny pan, motor mount bolts (I take out the intake manifold to make it easier but I hear you can leave it on. Its also a good idea to remove as many accessorys as possible but the power steering pump definetly needs to come out. Thats all I remember for now but will update/edit if I remembers anything else.
FormulaLT1
07-13-2006, 07:17 PM
Oh and the hood strut lower bolts need to be removed to allow the hood to open wide enough to be able to fit the engine out the top. I found a broom stick in by the air filter area worked well.
MMonnier2302
07-14-2006, 01:45 AM
thank you, its must appreciated
i spun a rod bearing, and the crank has got to be damaged also. its a hell of a lot cheaper to have a speed shop fix just the block, than it is to hand them the whole car
