fuel pump & starter
vpldivy
07-09-2006, 09:30 AM
I've had my grand prix se for 4 years without any problems at all. Last week I go to start back to work and stop @ the local speedway for a second, get back into the car and starter sounds horrible, will barely crank. I get it towed and next day dealer tells me that fuel pump has no pressure. I tell them to get it running and save the old fuel pump. I get a call to come pick it up the next day and when I get in it it won't start at all. Sounds the same way it did before it was towed. They tried to sell me a $500 starter. I told them not to touch it and I would furnish a starter the next day.
diagnosis: I think they botched the diagnosis and the starter was the whole problem and of course they put the starter on it for me for "FREE". I 'm thinking about taking them to court to recover the cost of the "bad" fuel pump. what do you think???
BNaylor
07-09-2006, 12:30 PM
Have you complained to the dealer that did the work? As long as the starter was the cause for sure, it won't hurt to put the dealer on notice and inform them you plan on seeking redress and take them to small claims court. I would not get a lawyer involved unless absolutely necessary. Save the old pump and starter as evidence. But make sure the old starter is bad and the old fuel pump is good. Good luck!
vpldivy
07-09-2006, 01:55 PM
thanks moderator!
HOW DO I MAKE SURE OLD FUEL PUMP STILL WORKS? CAN IT BE TESTED ONSITE @ A PARTS STORE? ALSO HOW CAN I TELL IF IT'S BAD JUST BY USE INSTEAD OF BAD BY TAMPERING?
BNaylor
07-09-2006, 02:48 PM
thanks moderator!
Re-installing it would be the best way. But you can connect 12 volts directly to the input pin and a ground to the ground pin for a very short period of time and listen to it spin. The 12 volt input (hot) must be fused with a 15 amp fuse for safety. To check flow you will have to submerge the fuel pump pod in a bucket of gasoline but I would not recommend doing that for obvious reasons. All it will take is one spark and you'll have mess on your hands. Do you have the complete fuel pump pod assembly like pictured below?
http://i5.photobucket.com/albums/y186/lizzywiz/fuelsender.jpg
vpldivy
07-09-2006, 08:14 PM
Yes, I do have both the pump and the old starter. Thanks for the info on how to test it.
question: Is Chilton's the best place to go for a full blown version of the repair manual? I don't want it on CD, I'd like something I can read and follow instructions from. I've done searches and don't know if their even published yet.
