Ignition Cylinder removal & replacement- help!!!
Young Chuck D
07-02-2006, 07:00 PM
FIRST Watch This Video (i took the video, its different from yesterday's, and yes that is my car)
http://www.youtube.com/watch?v=L-4WtyUjEpI
SECOND Pictures of what was too dark to show in the video
http://i5.tinypic.com/16gz6sk.jpg
http://i3.tinypic.com/16gz6vp.jpg
http://i5.tinypic.com/16gz71d.jpg
http://i4.tinypic.com/16gz769.jpg
ok, my delco ignition cylinder will be picked up from advance this morning at 10am et. then i'm going to come home and, either with your help or with my knack for poking my way through, install the new ignition cylinder.
leave your comments, advice, guidance, jokes:nono:, prayers, donations, and tears in a bucket below.
gremlin96
07-08-2006, 08:29 PM
simple fix. you probly seen the instructions that comes with the new key switch. all you need is a #3 philips. pull on the horn button. trun the wheel till you see the philps screew. there will be a hole that lines up in the center of the wheel. remove the screew. pull out old switch. push new one in its place put back philps screew.
bobss396
07-12-2006, 12:30 PM
Any other cylinder I had to change on a Chevy involved removeing the steering wheel and lock plate below that. I couldn't get the video to play on my POS PC at work, good luck.
Bob
Bob
