Is This A Good Engine Rebuild Kit?
EricSchnabel
07-01-2006, 10:54 PM
Does this kit include everything to rebuild the lower end of your engine for high hp output. Valves Down. And do you want Tabs for M. Bearings 1 way or Tabs for M. Bearings 1/2 left and 1/2 right. What is the difference.
Complete Gasket Set
Copper Performance Head Gasket
Wiseco Forged Pistons
Performance Rings
Performance Wrist Pins
TOGA HP Main Bearings
TOGA HP Rod Bearings
Thrust Washers
Timing Belt
Expansion Plugs
Tabs for M. Bearings 1-way
Tabs for M. Bearings 1/2 left, 1/2 right
TOGA HV Oil Pump
Re-Con Forged Crank
H-Beam Rods
Price: $1559
I plan on have massive amounts of hp when i am done with my car.
Complete Gasket Set
Performance Rings
Thrust Washers
Timing Belt
Expansion Plugs
TOGA HV Oil Pump
Re-Con Forged Crank
H-Beam Rods
Price: $1559
Blackcrow64
07-01-2006, 10:57 PM
Don't forget some ARP head studs, rod bolts, and main bolts... Also, the stock cranks are good for a ton of power... IIRC Shepherd still runs a stock crank...
EricSchnabel
07-01-2006, 11:05 PM
I have the 420A n/t motor in my 98 eclipse and i want to get about 600 or 700 hp out of the motor so will i still have to replace the crank. I plan on having to run a high amount of boost to do so like somewhere in the 40's. So those few things is all that it is missing to complete that parts of the engine rebuild.
l_eclipse_l
07-01-2006, 11:28 PM
:dupe: :wtf:
:dupe: :wtf:
Blackcrow64
07-01-2006, 11:31 PM
Holy shit... :eek:
Dude... No... You will never see 600-700hp out of the 420a. Especially if your only gonna build the bottom end... And you will never see 40psi on a 420a unless you drop like 25k into building the motor... Our built 4g63's are lucky to see 40psi without problems, and even then its just not a bottom end build... Wow... :shakehead
Holy shit... :eek:
blk_srt
07-02-2006, 12:24 AM
I hope you plan on dropping the compression ratio to 7.5:1, building the head and having $5k set aside for when you throw a rod:)
EricSchnabel
07-02-2006, 07:50 AM
I am going to rebuild the whole entire motor i am going to start with the bottom end and work my way up. I plan on dropping $20 Grand into it to get there.
ITSME4G63
07-02-2006, 07:54 AM
Just buy an evo for htat 20g, call it a day. Hell you can buy 600whp awd turbo dsms for less.
Talon69
07-02-2006, 09:54 AM
:iagree:
Blackcrow64
07-02-2006, 12:00 PM
Thats fine... Its your money and your choice... But in my opinion, that makes you the biggest dumbass I've ever met.
blk_srt
07-02-2006, 12:08 PM
:iagree:
