92 integra gs window question
LikeToJump
06-30-2006, 05:37 PM
I have a 92 integra gs 4 door 5 speed. My passenger rear window will not roll down. I put 12v to the window motor and the window goes up and down fine. I'm guessing that it must be a relay, I called the acura delership, and they told me that the relay was under the hood, WRONG. I was wondering if anyone here knows where the passenger rear window relay is. I searched both fuse boxes up and down, left to right about 9 times total and cant find it anywhere. My chilton manual tells me that it is below the left instument panel behind the fuse box kick panel, but when I look there the only relay I see is for the blower motor. Thanks!
steffenst
07-06-2006, 10:39 PM
I have a 90 Integra and i have a feeling the relay is in the same place. I installed power windows in my car. Try looking under the right side dash pannel. Its tricky to find, look inbetween the blower motor behind the glove box and the panaling and carpet. Look near the fire wall!!!You will Know when you find it. There are two large wires that are blue and one has a yellow stripe on it.
