Cruise Control Problems
GilDavis
06-28-2006, 05:16 PM
Has anyone heard of or experienced cruise control problems? Especially over-revving or runaway acceleration?:banghead:
Imac007
07-07-2006, 06:32 PM
haven't come across that problem. my cruise has stopped working ever since my water pump went (about 3 wks ago).......they can't be connected can they ????
woscarr
07-08-2006, 11:04 PM
1st. post
I nee dmore info about what's happening. You say it accelerates out of control ?! Maybe a sticky resume button ? Or something under the hood is obstructing the cruise control cables to the throttle ?!
2nd post
I would say definitely YES ! it would have something to do with the water pump repair. I would look for broken, disconnected wires/plugs in the engine compartment. If still nothing check the switch at the brake pedal.
Good Luck
2nd post
Good Luck
Imac007
07-11-2006, 07:09 PM
OK, heres what happened. on my way to work, in my 98 Venture, my water pump decided to go. I managed to make to work. Along the way my speedometer started acting eraticly and so did the cruise. Filled up rad and reservior with water to get home. replaced w/pump. now speedo still acts up and cruise doesn't work at all.
