93 chevy truck wont start
furface164
06-22-2006, 10:25 AM
Try the best I can. I have a 93 chevy Truck that died one day I found the ground wire from the block to the body was broken. I have replaced that wire . it started but then when i turned it off wont start. have replaced pos. wire from battery to starter. a new battery, pulled the starter and jumped the bolts and the starter turns and kicks in. so this what i have when i try to start it it just clicks and everything goes dead. thats with a new battery to. oh ya one time when we worked on it we saw aspark jump from a bracket on the block. im about to pull my hair out please help. :banghead:
gmtech79
06-22-2006, 09:41 PM
How about the ground from the battery to the engine block. Any corrosion anywhere. I know you have a new battery but what is the state of charge. Should be 12.6 volts. Do a voltage drop test on the ground from the battery to the block, no more than .3 volts should be seen with a voltmeter. Wouldn't hurt to do the positive from battery to the starter also. Check voltage drop while cranking the engine.
88mike
06-22-2006, 09:57 PM
sounds like wire from ignition switch to starter solenoid is bad, bad solenoid?
