Jeep Cherokee Grand 2003
shupi
06-22-2006, 03:01 AM
Hi,
I have a Jeep Cherokee Grand 2003 model RHD V8 Automatic.
I need to know the tightning torque and tightning sequence for the cylinder head bolts and the tightning torque for the camshaft sprocket bolt, camshaft bearing caps and camhaft pulley bolts.
I cannot seem to get my hands on the service manual but am trying. any help will be appreciated.
Shupi
xj31
06-22-2006, 08:23 PM
TORQUE
DESCRIPTION N·m Ft. In.
Lbs. Lbs.
Camshaft
Non - Oiled Sprocket Bolt 122 90 —
Bearing Cap Bolts 11 — 100
Timing Chain Cover—Bolts 58 43 —
Connecting Rod Cap—Bolts 27 20 —
PLUS 90° TURN
Bed Plate—Bolts Refer to Procedure
Crankshaft Damper—Bolt 175 130 —
Cylinder Head—Bolts
M11 Bolts 81 60 —
M8 Bolts 26 19 —
Cylinder Head Cover—Bolts 12 — 105
Exhaust Manifold—Bolts 25 18 —
Exhaust Manifold Heat Shield—Nuts 8 — 72
Then loosen 45°
Flexplate—Bolts 60 45 —
Engine Mount Bracket to Block—Bolts 61 45 —
Rear Mount to Transmission—Bolts 46 34 —
Generator Mounting—Bolts
M10 Bolts 54 40 —
M8 Bolts 28 — 250
Intake Manifold—Bolts 12 — 105
Refer to Procedure for
Tightening Sequence
Oil Pan—Bolts 15 — 130
Oil Pan—Drain Plug 34 25 —
Oil Pump—Bolts 28 — 250
Oil Pump Cover—Bolts 12 — 105
Oil Pickup Tube—Bolt and Nut 28 — 250
Oil Dipstick Tube to Engine
Block—Bolt 15 — 130
Oil Fill Tube—Bolts 12 — 105
Timing Chain Guide—Bolts 28 — 250
Timing Chain Tensioner Arm—Special
Pin Bolt 17 — 150
Hydraulic Tensioner—Bolts 28 — 250
Timing Chain Primary Tensioner—Bolts 28 — 250
Timing Drive Idler Sprocket—Bolt 34 25 —
Thermostat Housing—Bolts 13 — 115
Water Pump—Bolts 58 43 —
shupi
06-23-2006, 01:20 AM
XJ 31,
Thanks a ton for a promt reply. Ill work with these values and hope I get the desired results!!
Shupi
