Keyless Entry on 97 Blazer
brian97ls
06-21-2006, 03:02 PM
I have a 97 Blazer LS and the two keyless entry remotes I got with the car hardly work anymore. One does not work completely and the other only the lock and rear hatch 2x button work. I replaced the batteries on both and checked the insides to see for loose connections. I have read some posts on reprogramming but I didn't know if that is what I need to try and what reprogramming proceedure to try for that matter. Any help/thoughts thanks in advance.
brian97ls
06-22-2006, 08:00 AM
any thoughts anyone please help?????
mountie1982
06-22-2006, 08:21 AM
Check Ebay for new ones. Maybe the ones you got are old and worn out.
ZL1power69
06-22-2006, 10:26 AM
if u wanna try reprograming for the hell of it heres the procedure;
- remove the lower dash panel under the steering wheel (3-4 bolts)
- look in the upper left corner and u will see the remote entry box with a red connector comming out of it.
- with the doors closed, use a paperclip bent into a U and insert it into the red connector. u will hear the locks cycle and ur in programing mode.
- hold the unlock button (i believe) and u will here the locks cycle again. programing is finished
- repeat for the other remote
brian97ls
06-22-2006, 10:36 AM
ok thanks for the help
