firewall problem
gohdonfett
06-15-2006, 07:12 PM
ok so im trying to install a subwoofer in my cavalier but i don't know where to run the power cable through the firewall and i don't really wann try and drill a hole. any help?
BlasZ24
06-15-2006, 10:37 PM
You need to drill through the firewall it is not a big deal just use common sense to pick a good spot and be careful with the drill.
Cavalier2000
06-16-2006, 11:54 AM
theres a big rubber thign that is around your steering wheel conul just go through there and go under your carpet
KustmAce
06-16-2006, 08:12 PM
Thats where I have put every wire I have run
my99cavy
06-16-2006, 09:43 PM
theres a big rubber thign that is around your steering wheel conul just go through there and go under your carpetthats exactly where i ran all wires from. good call...
gohdonfett
06-16-2006, 09:56 PM
thank you. my firewall problem has been solved... but i got everything hooked up seemingly in the right order. but my amp won't turn on. i think i might have hooked up the remote cord to the wrong spot on my deck... other then that i have no clue... any suggestions?
notaricajustfasta
06-16-2006, 10:19 PM
blue wire with white stripe every time
gohdonfett
06-16-2006, 10:53 PM
thank you much i will fix that in the morning.
Young Chuck D
06-17-2006, 12:13 AM
how come when i know the answer to a question you pros get to it before me??
go answer some rear differential algebraic expression questions!
leave the easy stuff to me!
gohdonfett
06-17-2006, 11:25 AM
ok well i fixed my remote wire but... my amp still doesn't wanna get power... so im assuming my power cord is hooked up wrong... maybe its wired to the battery wrong? or maybe i wired it to the fuse the wrong way... i really have no clue soo yah any help?
BlasZ24
06-17-2006, 11:44 AM
First thing to do is check that there is Voltage on the power wires... Then if there is it is a problem with the remote turn on wire.
my99cavy
06-17-2006, 01:50 PM
leave the easy stuff to me!LMAO funny stuff man..:rofl: :rofl:
my99cavy
06-17-2006, 01:57 PM
ok well i fixed my remote wire but... my amp still doesn't wanna get power... so im assuming my power cord is hooked up wrong... maybe its wired to the battery wrong? or maybe i wired it to the fuse the wrong way... i really have no clue soo yah any help?do you have a good ground?
Cavalier2000
06-20-2006, 10:38 AM
check your grounf first that will do it every time. also check all of your fuses, (in the power line and on the amp) also make sure none of the wires are touching each other on the amp.
my99cavy
06-20-2006, 03:27 PM
check your grounf first that will do it every time. also check all of your fuses, (in the power line and on the amp) also make sure none of the wires are touching each other on the amp.fuses good call! i cant believe i forgot about them...:banghead:
