Trouble Code P0758
truc0011
06-07-2006, 10:20 AM
Has anybody run into this code? I know it is for the 2-3 shift solenoid, has replacing the solenoid solved your problems? I have a 2000 Montana, which sometimes shifts hard from 2-3, and even sometimes in other gears.
maxwedge
06-07-2006, 03:37 PM
Shift solenoids on these year GM tans were problematic. Should scan it and see if the solenoid is getting a signal from the pcm and check for slippage errors and other codes, a trans capable scanner is required here, most likely the solenoid packs and harness should all be replaced at one time and be done with it.
truc0011
06-21-2006, 05:22 PM
Has anybody replaced a 2-3 shift solenoid in a 2000 or similar Pontiac Montana, Chevy Venture, or Olds Silhoute?
maxwedge
06-21-2006, 08:00 PM
It is in the valve body inside the trans side cover, axle has to come out, subframe dropped to gain access to remove cover, difficult home "dyer" type repair.
