shuttering vibrations
mitglenford
06-07-2006, 09:06 AM
my 93 labaron gtc has a shuttering vibration at 38 mph. once you past this point or before this point everything is fine. I read that this problem is either due to an incorrect firing secquence or the torque converter. Any information would be helpful:screwy:
94LebConv3La604
06-07-2006, 12:17 PM
Could also be that you are in need of a front drive axle or two. I'm pretty sure an incorrect firing sequence would be felt as well as heard at any speed including idle.
87LeBarron
07-22-2006, 12:36 PM
Also may want to check your wheel balance and tire wear.
